[postgis-users] shp2pgsql
Nandorov
nandorov at gmail.com
Tue Sep 23 10:43:56 PDT 2008
i'm trying to use shp2pgsql. i use help command to see syntax but i have a
question. i hope you can help me :-D. Here's the syntax
shp2pgsql [options] [shape file] [schema][table]
how to point to a database that i want? i mean, how do i know which database
i'm inserting the data?
i executed with no options
shp2pgsql C:\shp\myshape.shp public.test_shp
it's supposed to create a table called test_shp in public schame. but i dont
in which database. command executed successfully but i can't see the data
anywhere. any help will be well received (:
thanks
View this message in context: http://www.nabble.com/shp2pgsql-tp19633152p19633152.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
