[postgis-users] shp2pgsql
Nandorov nandorov at gmail.com
Tue Sep 23 10:49:38 PDT 2008
my bad, i had to add | psql mydatabase
thanks, anyways
:D
Nandorov wrote:
> Hi,
> i'm trying to use shp2pgsql. i use help command to see syntax but i have a
> question. i hope you can help me :-D. Here's the syntax
> shp2pgsql [options] [shape file] [schema][table]
> how to point to a database that i want? i mean, how do i know which
> database i'm inserting the data?
> i executed with no options
> shp2pgsql C:\shp\myshape.shp public.test_shp
> it's supposed to create a table called test_shp in public schame. but i
> dont in which database. command executed successfully but i can't see the
> data anywhere. any help will be well received (:
> thanks
View this message in context: http://www.nabble.com/shp2pgsql-tp19633152p19633252.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
