[postgis-users] PgRouting in PostGIS
Anton Patrushev
anton at orkney.co.jp
Tue Sep 23 16:37:21 PDT 2008
Of course you can. You can put any float value as a cost. And if a
cost of an edge is high enough comparing to other costs, algorithm
will prefer not to pass through that edge.
Anton.
On 9/24/08, Nandorov <nandorov at gmail.com> wrote:
> can i block some segments? for example cad gives the posibility to put a max
> resistance value, let's say it's 100. So if the resistance of your segment
> is 100 that segment is blocked and you cannot go thorught this way. if this
> possible with pgrouting?
> thanks!
> Stephen Woodbridge wrote:
> > Nandorov wrote:
> >> hi,
> >> i've tried pgrouting algorithms and works pretty well. However, i dont
> >> know
> >> exactly the way they applied "the resistance" of a way (represented by a
> >> multilinestring). has someone worked with pgrouting before? and know if
> >> i
> >> can modify their algorithms to adapt them to my requirements?
> >> thanks
> > "the resistance" is applied as a "cost" to traverse the segment. All
> > cost must be positive. You can use length of the segment as cost for
> > shortest distance. or you can compute and assign a cost value based on
> > other attributes.
> > -Steve
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> View this message in context: http://www.nabble.com/PgRouting-in-PostGIS-tp19638201p19638473.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
