[postgis-users] PgRouting in PostGIS
Nandorov
nandorov at gmail.com
Wed Sep 24 08:16:25 PDT 2008
Hi Anton,
i have a problem when applying where clause in the sql parameter for
shortest_path function. Function seems to work well but how do i recover the
coordinates?
i used to do this way, for example
select * from shortest_path('SELECT
id,source,target,x1,y1,x2,y2,cost,reverse_cost from tb_mygeom',3989
,145,true,true); to verify and then applied:
insert into my_temptable(geom)
select the_geom from dijkstra_sp_directed('tb_mygeom',3989,145,true,true);
to recover the coordinates.
Now i applied
id,source,target,x1,y1,x2,y2,cost,reverse_cost from tb_mygeom where
isBlocked != ''Y'' ',3989 ,145,true,true);
the functions seems to work, but i dont know how to get the coordinates,
because if i apply dijkstra_sp_directed i can't filter there. I tried
INSERT INTO shortest_path_table_2(the_geom)
select the_geom from tb_mygeom
where gid in (
select vertex_id from shortest_path('SELECT
the_geom,id,source,target,x1,y1,x2,y2,cost,reverse_cost from full_calleslima
where is_blocked != ''Y'' '
,3989 ,145,true,true) );
but it returns a messy format, no linked vertix
thanks a lot
Anton A. Patrushev wrote:
> Hi Fernando,
> Of course you can use any SQL query with any filters you wish.
> That's actually what pgRouting was made for!
> Please read this:
> http://pgrouting.postlbs.org/wiki/Dijkstra
> http://pgrouting.postlbs.org/wiki/AStar
> http://pgrouting.postlbs.org/wiki/ShootingStar
> Anton.
> On 9/24/08, Nandorov <nandorov at gmail.com> wrote:
>> hi,
>> thanks Anton for your answer at pgrouting forum. i'm goingo to reply
>> here i
>> hope it's ok.
>> Hi Fernando,
>> I think I answered you already in the PostGIS mailing list.
>> Anyway, it is worth to repeat. You can block edges by assigning high
>> value
>> to cost field. Or, if you wish, you can add one more field, let's say,
>> of
>> boolean type and name it is_blocked, and then use core routing function
>> (not
>> wrapper), where you can limit your search area with non-blocked edges
>> only -
>> "SELECT ... WHERE NOT is_blocked".
>> So i the input sql statement at shortest path function can include where
>> filters? sounds nice. i'm going to try it later (00:16 here lol)
>> thanks a lot
>> > Hi,
>> > Of course you can. You can put any float value as a cost. And if a
>> > cost of an edge is high enough comparing to other costs, algorithm
>> > will prefer not to pass through that edge.
>> > Anton.
>> >> can i block some segments? for example cad gives the posibility to
>> put a
>> >> max
>> >> resistance value, let's say it's 100. So if the resistance of your
>> >> segment
>> >> is 100 that segment is blocked and you cannot go thorught this way.
>> if
>> >> this
>> >> possible with pgrouting?
>> >> thanks!
>> >> Stephen Woodbridge wrote:
>> >> > Nandorov wrote:
>> >> >> hi,
>> >> >> i've tried pgrouting algorithms and works pretty well. However, i
>> >> dont
>> >> >> know
>> >> >> exactly the way they applied "the resistance" of a way
>> (represented
>> >> by a
>> >> >> multilinestring). has someone worked with pgrouting before? and
>> know
>> >> if
>> >> >> i
>> >> >> can modify their algorithms to adapt them to my requirements?
>> >> >> thanks
>> >> > "the resistance" is applied as a "cost" to traverse the segment.
>> All
>> >> > cost must be positive. You can use length of the segment as cost
>> for
>> >> > shortest distance. or you can compute and assign a cost value
>> based on
>> >> > other attributes.
>> >> > -Steve
>> >> > _______________________________________________
>> >> > postgis-users mailing list
>> >> > postgis-users at postgis.refractions.net
>> >> > http://postgis.refractions.net/mailman/listinfo/postgis-users
>> >> View this message in context:
>> >> http://www.nabble.com/PgRouting-in-PostGIS-tp19638201p19638473.html
>> >> Sent from the PostGIS - User mailing list archive at Nabble.com.
>> http://www.nabble.com/PgRouting-in-PostGIS-tp19638201p19642156.html
View this message in context: http://www.nabble.com/PgRouting-in-PostGIS-tp19638201p19651195.html
