[postgis-users] PgRouting in PostGIS
Anton Patrushev anton at orkney.co.jp
Tue Sep 23 22:32:07 PDT 2008
Hi Fernando,
Of course you can use any SQL query with any filters you wish.
That's actually what pgRouting was made for!
Please read this:
http://pgrouting.postlbs.org/wiki/Dijkstra
http://pgrouting.postlbs.org/wiki/AStar
http://pgrouting.postlbs.org/wiki/ShootingStar
Anton.
On 9/24/08, Nandorov <nandorov at gmail.com> wrote:
>  hi,
>  thanks Anton for your answer at pgrouting forum. i'm goingo to reply here i
>  hope it's ok.
>  Hi Fernando,
>  I think I answered you already in the PostGIS mailing list.
>  Anyway, it is worth to repeat. You can block edges by assigning high value
>  to cost field. Or, if you wish, you can add one more field, let's say, of
>  boolean type and name it is_blocked, and then use core routing function (not
>  wrapper), where you can limit your search area with non-blocked edges only -
>  "SELECT ... WHERE NOT is_blocked".
>  So i the input sql statement at shortest path function can include where
>  filters? sounds nice. i'm going to try it later (00:16 here lol)
>  thanks a lot
>  Anton A. Patrushev wrote:
>  > Hi,
>  > Of course you can. You can put any float value as a cost. And if a
>  > cost of an edge is high enough comparing to other costs, algorithm
>  > will prefer not to pass through that edge.
>  > Anton.
>  >>  can i block some segments? for example cad gives the posibility to put a
>  >> max
>  >>  resistance value, let's say it's 100. So if the resistance of your
>  >> segment
>  >>  is 100 that segment is blocked and you cannot go thorught this way. if
>  >> this
>  >>  possible with pgrouting?
>  >>  thanks!
>  >>  Stephen Woodbridge wrote:
>  >>  > Nandorov wrote:
>  >>  >> hi,
>  >>  >> i've tried pgrouting algorithms and works pretty well. However, i
>  >> dont
>  >>  >> know
>  >>  >> exactly the way they applied "the resistance" of a way (represented
>  >> by a
>  >>  >> multilinestring). has someone worked  with pgrouting before? and know
>  >> if
>  >>  >> i
>  >>  >> can modify their algorithms to adapt them to my requirements?
>  >>  >> thanks
>  >>  > "the resistance" is applied as a "cost" to traverse the segment. All
>  >>  > cost must be positive. You can use length of the segment as cost for
>  >>  > shortest distance. or you can compute and assign a cost value based on
>  >>  > other attributes.
>  >>  > -Steve
>  >>  > _______________________________________________
>  >>  > postgis-users mailing list
>  >>  > postgis-users at postgis.refractions.net
>  >>  > http://postgis.refractions.net/mailman/listinfo/postgis-users
>  >>  View this message in context:
>  >> http://www.nabble.com/PgRouting-in-PostGIS-tp19638201p19638473.html
>  >> Sent from the PostGIS - User mailing list archive at Nabble.com.
> View this message in context: http://www.nabble.com/PgRouting-in-PostGIS-tp19638201p19642156.html
