[postgis-users] Calculating Attributes
Luigi Castro Cardeles
luigi.cardeles at gmail.com
Fri Apr 3 09:37:27 PDT 2009
Hi
be careful with units. This formula returns the area using projection's
units (degrees, meters, kilometers etc). If that's the case maybe convert to
some metric projetion
UPDATE table1 SET area_column = ST_AREA(ST_TRANSFORM(the_geom,
srid-of-metric-projection)); -- this returns, normally, square meters.
The problem is chose the right projection for your data (maybe more than
one).
2009/4/3 George Silva <georger.silva at gmail.com>
> Hello Aurora,
> In ArcGIS it's all different. In PostGIS you can use simple/complex SQL
> queries to "calculate values" in a similar fashion of arcgis.
> The simplest of them all would be, in your case:
> ALTER TABLE table1 ADD COLUMN area_column double precision;
> UPDATE table1 SET area_column = ST_AREA(the_geom);
> You can in that SQL query divide, multiply, and do whatever you want with
> that result that will be written to the column area_column.
> I hope that helps
> George
> On Fri, Apr 3, 2009 at 12:55 PM, Aurora Geomatics <
> aurorageomatics at gmail.com> wrote:
>> Hello PostGIS users,
>> I have just installed William Kyng's PostgeSQ/PostGIS packages for Mac OS
>> X.5
>> I have been playing with pgAdmin and QGIS with importing shapefiles into
>> PostGIS. Works dandy.
>> Now I am wondering how to solve Attribute Calculations.
>> Years of using ArcGIS and GRASS it is pretty straightforward on those
>> apps, and am stumped with PostGIS Attribute calculations..
>> For example, using a polygon feature;
>> Creating a new column, say AREA and filling with a calculation that is
>> Hectares.
>> Thanks!
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090403/6d689e0b/attachment.html>
