[postgis-users] Calculating Attributes
Aurora Geomatics
aurorageomatics at gmail.com
Fri Apr 3 09:48:37 PDT 2009
Thank you George,
On 3-Apr-09, at 9:22 AM, George Silva wrote:
> Hello Aurora,
> In ArcGIS it's all different. In PostGIS you can use simple/complex
> SQL queries to "calculate values" in a similar fashion of arcgis.
> The simplest of them all would be, in your case:
> ALTER TABLE table1 ADD COLUMN area_column double precision;
> UPDATE table1 SET area_column = ST_AREA(the_geom);
> You can in that SQL query divide, multiply, and do whatever you want
> with that result that will be written to the column area_column.
Pretty straight forward SQL statement.
Is this a matter of opening a Terminal session using psql monitor?
Is it possible through pgAdmin or QGIS?
Thanks.
> I hope that helps
> George
> On Fri, Apr 3, 2009 at 12:55 PM, Aurora Geomatics <aurorageomatics at gmail.com
> > wrote:
> Hello PostGIS users,
> I have just installed William Kyng's PostgeSQ/PostGIS packages for
> Mac OS X.5
> I have been playing with pgAdmin and QGIS with importing shapefiles
> into PostGIS. Works dandy.
> Now I am wondering how to solve Attribute Calculations.
> Years of using ArcGIS and GRASS it is pretty straightforward on
> those apps, and am stumped with PostGIS Attribute calculations..
> For example, using a polygon feature;
> Creating a new column, say AREA and filling with a calculation that
> is Hectares.
> Thanks!
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090403/6ea1d02a/attachment.html>
