[postgis-users] shp2pgsql not working
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Tue Aug 4 01:42:34 PDT 2009
Ravi wrote:
> Hi,
> shp2pgsql is again not working. Just a couple of days ago I thought not using
> -i in the options makes it work. But in vain.
> shp2pgsql –D -s 3005 bc_pubs.shp bcpubs > bc_pubs.sql
> gives 'Access Denied'.
> Ravi
Sorry, but if you see this with different option combinations then it's
just a standard file permissions issue. Check your file permissions
carefully.
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
