[postgis-users] Problem with ST_SymDifference function
    n.kolios
    n.kolios at gmail.com
    Tue Aug  4 01:55:22 PDT 2009
Hi Leo, thanks for your reply, these are two MULTIPOLYGON tables that I am
trying to compare.
Paragon Corporation-2 wrote:
> Nikos,
> What kind of geometries are you talking about? In some cases the
> ST_Symdifference will look the same as the original depending on the
> dimensionality of the input geometries.
> If you have two sets of polygons -- you'll see a difference but a line and
> polygon you may or may not because if the line intersects the polygon --
> the
> symetric difference will look like pretty much the union of the polygon
> with
> the line (if the line is completely contained by the polygon -- it will
> look
> like just the polygon (the union of the 2)
> Leo
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Kolios
> N.
> Sent: Monday, August 03, 2009 4:58 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Problem with ST_SymDifference function
> Hi all,
> I am using an ST_SymDifference query in order to visualize changes between
> two polygon tables.
> The result, however does not look correct. It includes the entire
> geometries
> of both tables rather than the portions that do not intersect.
> My query is the following:
> CREATE TABLE bu_delta as
> SELECT
> ST_SymDifference(t.the_geom, b.the_geom) AS difference_geom FROM
> bu_benchmark AS b, bu_test AS t WHERE ST_Intersects(t.the_geom,
> b.the_geom);
> (and then add gid)
> Has anyone ever done something similar?
> Thanks in advance,
> Nikos
> PS1: The geometries of my tables are such that one feature from one layer
> intersects with multiple features from the other layer.
> PS2: When I run this query for one isolated polygon from each table the
> result is OK.
> PS3: I also tried the ST_Difference function with no success.
> A picture might help:
> http://www.nabble.com/attachment/24716126/0/example_difference.TIF
> postgis-users mailing list
View this message in context: http://www.nabble.com/Problem-with-ST_SymDifference-function-tp24787408p24804662.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
