[postgis-users] TIGER Help/Clarification
Bo Coughlin bo at rekindl.com
Tue Aug 4 08:36:46 PDT 2009
That's for sure...huge amount.  So, the feature tables
should be used as a reference? Meaning it should not actually be
loaded but used as
a "reference" to make the necessary foreign key index within the shape
tables? - thanks very much - bo
On Tue, Aug 4, 2009 at 10:42 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Bo Coughlin wrote:
>> Using the TIGER shp files is a no brainer (feel free to disagree). My
>> question is on the relationship tables, and setting up the DB in postGIS.
>>  What role do these tables play?  While it seems self explanatory in that
>> the foreignkey relationship etc. is outlined in a very nice diagram by the
>> census - I am still a little lost on how to integrate into the DB - do I
>> import those create the foreign key relationships between them and then do
>> the same with each shp. file?
>> This is definitely a noob question, but I am simply struggling with the
>> exact relationship of these tables with the shp files -  there doesn't
>> appear to be a foreign key relationship between the shp's - but there does
>> between shp and relationship files.  Any help much appreciated. - thanks, bo
> The Tiger shapefiles are a dump of the Census relational data model. You
> can reload all the data you need and then use the relationships described to
> create foreign keys or to create views or new tables.
> There are a lot of files and tables to deal with, so do not expect it to be
> trivial especially if you want to load all the data.
> -Steve W
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090804/f8b0e259/attachment.html>
