[postgis-users] ST_Dump-like function for simple (non-multi) geometries ?
Kevin Neufeld
kneufeld at refractions.net
Tue Aug 4 08:39:47 PDT 2009
Nice. I posted your function to the trac ticket for this function. (http://trac.osgeo.org/postgis/ticket/76)
I am a little concerned about scalability, but we'll see what the team thinks.
Good work.
-- Kevin
Maxime van Noppen wrote:
> On 07/31/09 20:20, Kevin Neufeld wrote:
>> Unfortunately, I think your solution is overly simplistic.
> Of course, it is a little function dedicated to a specific use case for
> my program.
>> I think the
>> community is after something that mimics the ST_Dump and ST_DumpRings
>> functionality.
> I agree.
>> ie.
>> SELECT (ST_Dump('MULTILINESTRING((0 0, 1 1),(2 2, 3 3))'::geometry)).*;
>> path | geom
>> {1} |
>> 01020000000200000000000000000000000000000000000000000000000000F03F000000000000F03F
>> {2} |
>> 0102000000020000000000000000000040000000000000004000000000000008400000000000000840
>> (2 rows)
>> In order to extract all the points from every geometry in a table we
>> would need to be able to have this example query work that also returns
>> a SETOF geometry_dump:
>> SELECT (ST_DumpPoints(the_geom)).*
>> FROM my_spatial_table;
>> The path portion of the geometry_dump datatype is important because
>> users know the index of POINT in the geometry. It'll be possible then,
>> for example, to extract all but the endpoints. Additionally, users
>> could group the points back together to rebuild the original geometry
>> from whence they came.
>> Also, your function would need to be a lot more robust (ie. ideally,
>> able to accept all geometry types, POINT, LINESTRING, MULTIPOLYGON,
>> GEOMETRYCOLLECTION, etc).
>> I agree, the st_dump code does indeed look a little overwhelming. I
>> don't think we're tied to having the function written in C (there are
>> many plpgsql functions in PostGIS).
> The only problem with plpgsql functions is that in versions prior to
> PostgreSQL 8.4 you cannot mimic the 'RETURN SETOF' of the C. [1]
> This can be solved by adding a sql function wrapper though.
> [1]
> http://www.depesz.com/index.php/2008/11/03/waiting-for-84-pl-srf-functions-in-selects/
>> If you think you can come up with
>> something that meets the desired specifications, please, by all means,
>> feel free to propose something to the postgis-devel list. We'd love the
>> help!
> Here is a first draft (code is attached). The function handles any kind
> of geometries and path.
> - POINT
>> # SELECT path,astext(geom) FROM (SELECT (my_ST_DumpPoints('POINT(0 0)')).*) AS foo;
>> path | astext
>> {1} | POINT(0 0)
> - MULTIPOINT
>> # SELECT path,astext(geom) FROM (SELECT (my_ST_DumpPoints('MULTIPOINT((0 0), (1 1), (2 2))')).*) AS foo;
>> path | astext
>> {1,1} | POINT(0 0)
>> {2,1} | POINT(1 1)
>> {3,1} | POINT(2 2)
> - LINESTRING
>> # SELECT path,astext(geom) FROM (SELECT (my_ST_DumpPoints('LINESTRING(0 3, 1 4, 1 5)')).*) AS foo;
>> path | astext
>> {1} | POINT(0 3)
>> {2} | POINT(1 4)
>> {3} | POINT(1 5)
> - CIRCULARSTRING
>> # SELECT path,astext(geom) FROM (SELECT (my_ST_DumpPoints('CIRCULARSTRING(0 3, 1 4, 1 5)')).*) AS foo;
>> path | astext
>> {1} | POINT(0 3)
>> {2} | POINT(1 4)
>> {3} | POINT(1 5)
> - MULTILINESTRING
>> # SELECT path,astext(geom) FROM (SELECT (my_ST_DumpPoints('MULTILINESTRING((0 3, 1 4, 1 5),(10 10, 15 10, 42 42))')).*) AS foo;
>> path | astext
>> {1,1} | POINT(0 3)
>> {1,2} | POINT(1 4)
>> {1,3} | POINT(1 5)
>> {2,1} | POINT(10 10)
>> {2,2} | POINT(15 10)
>> {2,3} | POINT(42 42)
> - POLYGON
>> # SELECT path,astext(geom) FROM (SELECT (my_ST_DumpPoints('POLYGON((0 0, 50 50, 42 42, 0 0))')).*) AS foo;
>> path | astext
>> {1} | POINT(0 0)
>> {2} | POINT(50 50)
>> {3} | POINT(42 42)
>> {4} | POINT(0 0)
> - MULTIPOLYGON
>> # SELECT path,astext(geom) FROM (SELECT (my_ST_DumpPoints('MULTIPOLYGON(((0 0, 1 1, 2 2, 0 0)), ((50 50, 40 40, 30 30, 50 50)))')).*) AS foo;
>> path | astext
>> {1,1} | POINT(0 0)
>> {1,2} | POINT(1 1)
>> {1,3} | POINT(2 2)
>> {1,4} | POINT(0 0)
>> {2,1} | POINT(50 50)
>> {2,2} | POINT(40 40)
>> {2,3} | POINT(30 30)
>> {2,4} | POINT(50 50)
> - GEOMETRYCOLLECTION
>> # SELECT path,astext(geom) FROM (SELECT (my_ST_DumpPoints('GEOMETRYCOLLECTION(POINT(0 0), POLYGON((10 10, 20 10, 20 20, 10 10)))')).*) AS foo;
>> path | astext
>> {1,1} | POINT(0 0)
>> {2,2} | POINT(20 10)
>> {2,3} | POINT(20 20)
>> {2,4} | POINT(10 10)
> postgis-users mailing list
