[postgis-users] ST_Union (8.4) and TopologyException
pcreso at pcreso.com pcreso at pcreso.com
Tue Aug 4 16:56:04 PDT 2009
Hi Simon,
I've found the simplest way, if you don't have too many such instances, is to open the offending table in QGIS, zoom into the specified location, identify & fix the problem manually.
There are a number of possible topological errors which can occur, & this way allows a choice of solution, usually move or delete a point or two, or a hole...
You can do similar things with OpenJUMP & other FOSS GIS tools as well I believe.
Cheers,
  Brent Wood
--- On Wed, 8/5/09, Simon Greener <simon at spatialdbadvisor.com> wrote:
> From: Simon Greener <simon at spatialdbadvisor.com>
> Subject: [postgis-users] ST_Union (8.4) and TopologyException
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Date: Wednesday, August 5, 2009, 11:51 AM
> I have been trying out the new
> ST_Union in 1.4 and have a question.
> I note that, whenever I hit an error like this:
> NOTICE:  TopologyException: found non-noded
> intersection between 5.74214e+006 7.36573e+006, 5.74304e+006
> 7.36666e+006 and 5.74339e+006 7.36629e+006, 5.74304e+006
> 7.36666e+006 5.74304e+006 7.36666e+006
> ST_Union fails to produce a result.
> Is there anything I can do to address this
> TopologyException issue within PostGIS.
> regards
> Simon
> SpatialDB Advice and Design, Solutions Architecture and
> Programming,
> Oracle Database 10g Administrator Certified Associate;
> Oracle Database 10g SQL Certified Professional
> Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE,
> Manifold GIS, FME, Radius Topology and Studio Specialist.
> 39 Cliff View Drive, Allens Rivulet, 7150, Tasmania,
> Australia.
> Website: www.spatialdbadvisor.com
>   Email: simon at spatialdbadvisor.com
>   Voice: +61 362 396397
> Mobile: +61 418 396391
> Skype: sggreener
> Longitude: 147.20515 (147° 12' 18" E)
> Latitude: -43.01530 (43° 00' 55" S)
> NAC:W80CK 7SWP3
> postgis-users mailing list
