[postgis-users] union operation
lighthousej at gmail.com
Fri Aug 7 05:04:51 PDT 2009
Thanks for the replies.
Here's my version info:
postgis_full_version
POSTGIS="1.3.5" GEOS="3.0.3-CAPI-1.4.2" PROJ="Rel. 4.6.1, 21 August 2008"
USE_STATS
I see the version of GEOS is lower than the 3.1.1 that you recommend. I
thought at one point I was using that 3.1.1 version.
I did read up on the new union algorithm and how it speeds up the process,
but if upgrading fixes this too, I'm up for using it.
I just tried to install Pg 8.4.0 via linux installer, but I didn't see any
PostGIS package in stackbuilder?
I can test it's capability by compiling it on my box, but it has to be in
stackbuilder before I can use it.
The geometries themselves look okay, they specify polygons that have some
area.
I don't have any handy at the moment, but I will run them through the
isvalid() function and take your .sql file into consideration.
Any more things to look at would be much appreciated.
Thanks,
Nate
On Aug 7, 2009 3:14am, "Suhr, Ralf" <Ralf.Suhr at itc-halle.de> wrote:
> Your have some invalid geometries.
> Use
> update table set geom = cleangeometry(geom) where isvalid(geom) = FALSE;
> The SQL-Function can be found at
> http://www.sogis1.so.ch/sogis/dl/postgis/cleanGeometry.sql
> Gr Ralf
> -----Ursprüngliche Nachricht-----
> Von: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] Im Auftrag von
> Nathan Widmyer
> Gesendet: Freitag, 7. August 2009 00:41
> An: PostGIS Users Discussion
> Betreff: [postgis-users] union operation
> I have many polygons I'm trying to make a union of. The polygons have a
> high possibility of shared vertices which causes the "NOTICE:
> TopologyException: found non-noded intersection between ..." error.
> How can I avoid this error?
> I did find a reasonable query that used linework which solved that
> problem, but was problematic in other ways I think (I forgot those other
> circumstances). _______________________________________________
> postgis-users mailing list postgis-users at postgis.refractions.net
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090807/ca55958f/attachment.html>
