[postgis-users] Invalid OGC WKT (does not start with P, L, M, C or G) - but just on INSERT
Andreas Kalsch andreaskalsch at gmx.de
Sun Aug 9 03:13:23 PDT 2009
Why is this error thrown although the text is valid? When I select, it
will not be thrown.
b=# insert into feature_geom values('Relation', 1,
ST_GeomFromText('MULTIPOLYGON(((0 0,1 1,2 2,0 0)))', 4326));
ERROR:  Invalid OGC WKT (does not start with P,L,M,C or G)
CONTEXT:  SQL function "st_geomfromtext" statement 1
PL/pgSQL function "feature_geom_insert" line 6 at assignment
b=# select st_geomfromtext('POINT(0 0)', 4326);
                  st_geomfromtext
 0101000020E610000000000000000000000000000000000000
(1 row)
b=# select st_geomfromtext('MULTIPOLYGON(((0 0)))', 4326);
ERROR:  geometry requires more points
b=# select st_geomfromtext('MULTIPOLYGON(((0 0,1 1,2 2,0 0)))', 4326);
st_geomfromtext
 0106000020E6100000010000000103000000010000000400000000000000000000000000000000000000000000000000F03F000000000000F03F0000000000000040000000000000004000000000000000000000000000000000
b=# SELECT postgis_full_version() ;
 POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.1, 21 August
2008" USE_STATS
(1 row)
