[postgis-users] Invalid OGC WKT (does not start with P, L, M, C or G) - but just on INSERT
Kevin Neufeld
kneufeld at refractions.net
Sun Aug 9 18:13:02 PDT 2009
Also, just an FYI, the MULTIPOLYGON you are using as a test case is
invalid - there is no area as the boundary is actually a straight line,
a self-intersecting linestring that doubles back on itself.
-- Kevin
Paragon Corporation wrote:
> Andreas,
> You really should qualify the columns you are inserting into. Most likely
> the is is the order of columns in your table is different from how you are
> inserting. Its quite possible you are not inserting the geometry into the
> geometry column. Do something like this instead then you don't have to
> worry about the physical order of your columns
> insert into feature_geom(some_field, gid, the_geom)
> values('Relation', 1,
> ST_GeomFromText('MULTIPOLYGON(((0 0,1 1,2 2,0 0)))', 4326));
> Leo
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Andreas
> Kalsch
> Sent: Sunday, August 09, 2009 6:13 AM
> To: PostGIS Users Discussion
> Subject: [postgis-users] Invalid OGC WKT (does not start with P, L, M, C or
> Why is this error thrown although the text is valid? When I select, it will
> not be thrown.
> b=# insert into feature_geom values('Relation', 1,
> ERROR: Invalid OGC WKT (does not start with P,L,M,C or G)
> CONTEXT: SQL function "st_geomfromtext" statement 1
> PL/pgSQL function "feature_geom_insert" line 6 at assignment
> b=# select st_geomfromtext('POINT(0 0)', 4326);
> st_geomfromtext
> 0101000020E610000000000000000000000000000000000000
> (1 row)
> b=# select st_geomfromtext('MULTIPOLYGON(((0 0)))', 4326);
> ERROR: geometry requires more points
> b=# select st_geomfromtext('MULTIPOLYGON(((0 0,1 1,2 2,0 0)))', 4326);
> st_geomfromtext
> 0106000020E61000000100000001030000000100000004000000000000000000000000000000
> 00000000000000000000F03F000000000000F03F000000000000004000000000000000400000
> b=# SELECT postgis_full_version() ;
> POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.1, 21 August
> 2008" USE_STATS
> (1 row)
> postgis-users mailing list
