[postgis-users] functions st_covers, st_coveredby, st_simplifypreservetopology does not exist
Pena Kupen
kupen at wippies.fi
Fri Aug 14 05:29:22 PDT 2009
I cannot find it from my current path - should it be?
it is located on /usr/local/bin/
and when runnig it as
/usr/local/bin/geos-config --version
I got 3.1.1
pk
Mark Cave-Ayland <mark.cave-ayland at siriusit.co.uk> kirjoitti:
> Pena Kupen wrote:
> > Hi,
> > I install geos 3.1.1 from source and try the same.
> > There where no difference - same errors occurred again.
> > How to find out, which version of geos my scripts are using?
> > ideas?
> > pk
> In the 1.3 branch, PostGIS simply picks up the version of GEOS as
> indicated by the geos-config executable in the current path. So the
> quick check would be:
> HTH,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> Sirius Labs: http://www.siriusit.co.uk/labs
> postgis-users mailing list
Saunalahti DataPaketti - tilaa nyt, saat 2 kk veloituksetta ja Nettitikun kaupan päälle!
http://saunalahti.fi/gsm/gsmdatapaketti.php
