[postgis-users] How do you obtaining a WGS-84 (4326) coordinate from a coordinate that has no SRID
Eric B. Powell
ebpowell.chip at gmail.com
Wed Aug 19 19:27:53 PDT 2009
Rick wrote:
> On Wed, Aug 19, 2009 at 5:53 PM, Eric B. Powell
> <ebpowell.chip at gmail.com <mailto:ebpowell.chip at gmail.com>> wrote:
> ILAN BENISTY wrote:
> Hi,
> I am dealing with a problem where I am importing an AutoCAD
> description of an airport (DXF) into PostGIS.
> I have a Python script which will import each coordinate to a
> PostGIS geometry with SRID = -1 (since I do not have real
> world coordinates, but Cartesian coordinates from a point of
> origin).
> I do, however, have a lat/long reference point, which
> represents the origin of my x/y CAD coordinates.
> I would like to be able to store my CAD coordinates points as
> Long/Lat (SRID=4326).
> Any suggestions?
> Thanks,
> Ilan
> postgis-users mailing list
> <mailto:postgis-users at postgis.refractions.net>
> I'll answer for Ilan, we work together
> What country is the site in? What units are used for the drawings
> grid? Do you know the geographic datum?
> Country: Canada, Units: meters, Datum: WGS84
> I expect the solution is straightforward, but it is not obvious to us.
> It may require a fair amount of pre-processign before the data can
> be accurately (de)projected to LatLong.
> Once the details of the drawing grid are known, there is a python
> wrapper for Proj4 which could be used to (de)project the points on
> the way into the database.
> We are very experienced programmers, but have a limited knowledge of
> SQL. We've been working with it for a few years, but at this point
> have been able to get by quite nicely with the basics.
> We have a fair knowledge of Geodesy. It was my major, 20 years ago.
> I'll give you the use case:
> Currently we have a geometric database using PostgreSQL geometry types
> to represent aerodromes. The origin of the grid is the centroid of
> the aerodrome, and that we have a Geodetic position for. We use it,
> amoung other things, to plot radar targets. The radar data arrives on
> the same grid, so up to this point our data registers, we display the
> live radar data as SVG in any browser that is not IE with one second
> updates. This works well.
> However, for many reasons, we have to go to a geodetic system. We'll
> still use the same metric grid with an origin at the centroid for
> radar data, but to integrate with other systems we must maintain a
> geodetic database.
> The aerodrome data arrives as DXF. We have written an import filter
> in Python that parses in the DXF and converts it to Postgresql
> geometry. It also maps the layer names to a standard. Ilan, the
> author of this thread, is tasked with converting this to PostGIS so
> that we may merge with other systems that maintain geometry in WGS84.
> The general coverage of the data is three or four kilometers. Surface
> radar data arrives at a resolution of one meter, so if our accuracy is
> within 10cm we are more than good. We assume a reasonably accurate
> centroid position and a Cartesian plane that does not extend more than
> 3 kilometers in any direction from the origin, so curvature error is
> not an issue.
> The problem:
> We have a metric cartesian data set.
> We have a geodetic coordinate for the centroid of the aerodrome, which
> is the origin of our metric Cartesian data.
> We need to convert this to geodetic to exchange data with other
> components of the air navigation system.
> It seems to me that the solution might be to have PostGIS give us a
> coordinate for the centroid, transform the DXF coordinates during the
> parse operation, and then import it into PostGIS.
> We don't know how to properly do that, and it's quite possible that
> that is not the ideal solution.
> As I said, we are new to PostGIS, but we are keen to play.
> Eric
> Cheers!
> Rick
I was thinking that, if you know the actual location of your points in a
projected coordinate system, (de)projecting them to LatLong on the way
into PostGIS could be done using the pyProj library which wraps Proj4 in
a python wrapper. As such, as the points are read in, re-project them
and write them in using st_geometryfromtext().
I have an example of this approach I can send if you like.
Regards,
Eric
