[postgis-users] getting a square/rectangle arround a point
Daniel Grum
daniel.grum at unibw.de
Thu Aug 20 07:29:07 PDT 2009
>> Pavel Iacovlev schrieb:
>>> st_intersection(st_envelope(st_buffer(t1.the_geom, $radius)), t2.
>>> the_geom)
>>> 2009/8/18 Daniel Grum <daniel.grum at unibw.de>:
>>>> Dear Mailing-List,
>>>> I want to create a square/rectangle around a point-->via
>>>> box2d(geometry) or
>>>> buffer(geometry, double precision) for example.
>>>> If I have this rectangle I want to intersect this with another
>>>> polygon-->
>>>> saved in the (geodata) table: wald_by column: the_geom, to get
>>>> information
>>>> about the area the the "lumberjack" can dig.
>>>> The point in the middle of the rectangle = the point that is saved
>>>> in a
>>>> table in my database in the table: holzfaeller in the column the_geom!
>>>> Is this possible to solve?
>>>> Do I have to save this calculated square/rectangle in an extra/own
>>>> table?
>>>> Thanks for every help.
>>>> Daniel
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> I try solve the problem with your message:
>> SELECT st_intersection(st_envelope(st_buffer('holzfaeller.the_geom',
>> 10, 'quad_segs=8')),wald_by.the_geom);
>> I get this error message:
>> FEHLER: parse error - invalid geometry
>> ********** Fehler **********
>> SQL Status:XX000
>> What do you think is the problem in this case.
>> Is there a understaning mistake in my SQL order.
>> Thanks,
>> Daniel
> I thing I solved the problem:
> SELECT st_intersection(st_envelope(st_buffer(a.the_geom,1)),b.the_geom)
> FROM public.holzfaeller a, public.wald_by b
> (WHERE a.gid=3); //not necessary
> Thank You Pavel for the fast answer!
The problem now:
this order calculates a lot of points and the intersection with the
layer "wald_by" can't be solved because the geo data typ is:
GEOMETRYCOLLECTION.
I tried to generate a rectangle with ST_GeomGromText instaead of the
st_buffer that generates a circle:
ST_GeomFromText('POLYGON((st_x(a.the_geom)-2.0
st_y(a.the_geom)+2.0,st_x(a.the_geom)+2.0
st_y(a.the_geom)-2.0,st_x(a.the_geom)-2.0
st_y(a.the_geom)-2.0,st_x(a.the_geom)-2.0 st_y(a.the_geom)+2.0))')
PostgreSQL don't alerted me with a mistake, but if I would look for the
generated data, PostgreSQL isn't able to do this and said "Bricht ab".
What can be the reason for this?
Thanks
Daniel
