[postgis-users] Select Count
Bob Pawley
rjpawley at shaw.ca
Thu Aug 20 09:33:19 PDT 2009
Hi
When I use this expression I get results that are not correct. (More rows than the table p_id.image contains)
select count
(p_id.image.the_geom)
from p_id.image, processes_count , p_id.p_id , graphics.spatial_ref
where p_id.image.p_id_id = processes_count.p_id_id
and p_id.image.description = 'ip_op_Arrow_name'
and p_id.image.the_geom |>> p_id.p_id.ithe_geom
and p_id.image.the_geom << p_id.p_id.one
and p_id.p_id.process_number = '1'
and p_id.p_id.p_id_id = processes_count.p_id_id;
However, when I use the limited
select count
and p_id.image.description = 'ip_op_Arrow_name' ;
the correct results are obtained.
It woiuld appear that rows in other tables are being counted when I attempt to limit the return.
Can anyone suggest a workaround?/
Bob
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090820/670852ef/attachment.html>
