[postgis-users] problem with st_collect()
Kevin Neufeld
kneufeld at refractions.net
Thu Aug 20 11:35:12 PDT 2009
Ah. How are you viewing the table? Spatially though a GIS application, a psql terminal client, or just through
PgAdminIII? PgAdmin has issues displaying fields over a certain size.
-- Kevin
Marc-André Trottier wrote:
> ok thanks for the advise.
> finally i got a result but the field 'the_geom' is blank in my table.
> i calculate the size of the geometry with st_mem_size() and when the
> geometry is bigger than 32000 bytes, approximately, the field 'the_geom'
> is blank but there is a geometry.
> Marc-André
> 2009/8/20 Kevin Neufeld <kneufeld at refractions.net
> <mailto:kneufeld at refractions.net>>
> Be careful with ST_Collect. As the name implies, it will collect
> all the geometries in the set into a single geometry object. If
> your table is gigabytes in size, running over the whole table will
> create a single geometry collection that is gigabytes in size ...
> which in all likelihood is really rather useless in any GIS
> application and will probably overwhelm your postgresql instance.
> ST_Collects is definitely useful, but just be sure you really want a
> single (potentially very large and clumsy) geometry object.
> -- Kevin
> hi!
> i have a problem with this request :
> select st_collect(geometryN(setsrid(the_geom, 32198),1)) from
> 'table_name';
> this will return no results if "the_geom" contain too much rows
> or "the_geom" are too complex.
> How can i solve this problem ?
> thanks
> Marc-andré
> postgis-users mailing list
> <mailto:postgis-users at postgis.refractions.net>
