[postgis-users] 1.3 to 1.4 upgrade
Matt Foster
Matthew.Foster at noaa.gov
Fri Aug 21 05:51:29 PDT 2009
When you say you restore your 1.3 on top of a new 1.4 install, do you
mean that you dump your data only from the 1.3, and insert that into the
new 1.4? I didn't know that would work.
I did use the Perl script.
This on on RHEL 5 x86_64.
Matt
Paragon Corporation wrote:
> Those errors look fine to me. Those things don't exist in PostGIS 1.4 so
> they simply won't be loaded.
> Are you using the perl upgrade script. Haven't tried that so not absolutely
> sure. We usually just restore our old 1.3 ontop of a new mint PostGIS 1.4
> and that works pretty well for us, but then again we were doing both
> migrations at the same time.
> Which platform are you on by the way?
> Leo
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Matt
> Foster
> Sent: Thursday, August 20, 2009 12:06 PM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] 1.3 to 1.4 upgrade
> Hello,
> I'm moving some Postgis databases to a new physical server. I decided to
> use this opportunity to move from Postgis 1.3 to 1.4. I'm also going from
> Postgres 8.2 to 8.3 (I'm not brave enough to go to the brand new PG 8.4!).
> I concluded that the right thing to do was to use the "Hard Upgrade"
> method to make this move. When I ran the upgrade Perl script to restore the
> dump on to the new server, I got the following error messages...
> ERROR: language "plpgsql" already exists
> ERROR: function st_histogram2d_in(cstring) does not exist
> ERROR: could not access file "$libdir/liblwgeom": No such file or directory
> ERROR: function public.asukml(geometry, integer, integer) does not exist
> ERROR: function public.asukml(geometry, integer) does not exist
> ERROR: function public.asukml(geometry) does not exist
> ERROR: function public.st_asukml(geometry, integer, integer) does not exist
> ERROR: function public.st_asukml(geometry, integer) does not exist
> ERROR: function public.st_asukml(geometry) does not exist
> ERROR: function public.st_text(boolean) does not exist
> ERROR: function public.text(boolean) does not exist
> Following the documentation, I grep'd for ^KEEPING in the log file I
> created, and found these entries...
> KEEPING TYPE [histogram2d]
> KEEPING FUNCTION: [askml(geometry, integer, integer)] KEEPING FUNCTION:
> [asukml(geometry, integer, integer)] KEEPING FUNCTION: [asukml(geometry,
> integer)] KEEPING FUNCTION: [asukml(geometry)] KEEPING FUNCTION:
> [st_askml(geometry, integer, integer)] KEEPING FUNCTION:
> [st_asukml(geometry, integer, integer)] KEEPING FUNCTION:
> [st_asukml(geometry, integer)] KEEPING FUNCTION: [st_asukml(geometry)]
> KEEPING FUNCTION: [st_text(bool)] KEEPING FUNCTION: [text(bool)] KEEPING
> FUNCTION: [update_geometry_stats()] KEEPING FUNCTION:
> [update_geometry_stats(character varying, character varying)] KEEPING
> AGGREGATE [geomunion(geometry)]
> Are these messages normal or are they indicating a problem? Some searching
> of the mailing list archive led me to believe that they are normal, but I
> would like to be sure before I proceed with the other databases.
> Matt
> Do not go where the path may lead; go instead where there is no path and
> leave a trail.
> -- Ralph Waldo Emerson
> postgis-users mailing list
Do not go where the path may lead; go instead where there is no path and leave a trail.
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090821/9198e77d/attachment.vcf>
