[postgis-users] PostGIS layer spatial tolerance
Oxenstierna Andreas Andreas.Oxenstierna at sweco.se
Sun Aug 30 23:50:08 PDT 2009
Thanks.
SnapToGrid used in a trigger should, as far as I understand, act as a layer spatial tolerance.
Then we "just" need to ensure that all editing operations act accordingly, i.e. not shift any coordinate outside of the selected tolerance.
Best Regards
Andreas Oxenstierna
Telefon direkt 040-16 70 17
Mobil 0734-12 80 17
andreas.oxenstierna at sweco.se
Sweco Position AB
Hans Michelsensgatan 2
Box 286
201 22 Malmö
Telefon 040-16 70 00
www.sweco.se
-----Ursprungligt meddelande-----
Från: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] För Picavet Vincent
Skickat: den 28 augusti 2009 15:22
Till: PostGIS Users Discussion
Ämne: Re: [postgis-users] PostGIS layer spatial tolerance
> I come from the ESRI and Oracle world. Both ArcSDE and Oracle Spatial
> have user-defined spatial tolerance for each spatially enabled layer.
> This ensures that coordinates are exact, down to the last decimal (or
> integer for ArcSDE).
> I cannot find in the documentation or in the functionality that
> PostGIS has an awareness of spatial tolerance. What I can find is:
> "All floating point comparisons within the SQL-MM implementation are
> performed to a specified tolerance, currently 1E-8"
> but nothing about actual storage.
A solution in order to take spatial tolerance into account, despite not being automated, would be to systematically use the st_snaptogrid postgis function when creating or modifying geometries.
http://postgis.refractions.net/docs/ST_SnapToGrid.html
If you want a certain level of automation of this process, you should consider writing a trigger which snaps geometries to a specified grid on insert or update.
This is probably better than rounding coordinate in the application code.
Regards,
Vincent
> For me, the easiest solution would be to use a spatial tolerance.
> Otherwise, we may need to round all coordinates in the application
> code to e.g. 14 valid digits.
> Best Regards
> Andreas Oxenstierna
> Mobil 0734-12 80 17
> Sweco Position AB
> Box 286
> 201 22 Malmö
> www.sweco.se
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090831/57d720e9/attachment.html>
