[postgis-users] Length of Bigint, Double and Text fields
Chris Hermansen
chris.hermansen at timberline.ca
Tue Dec 1 08:49:53 PST 2009
Peter;
The canonical description of DBase files seems to be
http://www.clicketyclick.dk/databases/xbase/format/
On Tue, 2009-12-01 at 17:28 +0100, Peter Hopfgartner wrote:
> >> Dear PostGIS devels,
> >> since we right in the middle of comparing interoperability of shape
> >> files between some FOSS programs and ArcGIS, we encoutered also the
> >> following:
> >> gvSIG chokes on the Bigint as produced by pgsql2shp. Looking at
> >> ArcGIs generated files, the max length for numbers is 19, compared to
> >> 20 for integers and 32 for floating points as in pgsql2shp. This
> >> seems to be confirmed by some Borland tools, when configured for
> >> dBase III+.
> >> Another limit seems to be that of text fields, that must be no longer
> >> then 254. This is the maximum as given by ArcGIS and by the Borland
> >> tool.
> >> Another point is Boolean: ArcGIS seems to not allow the creation of
> >> boolean fields and the Borland Tool ("Database Desktop") says that
> >> Booleans have a length of 1.
> >> Regards,
> >> Peter
> > Hi Peter,
> > You've brought up some interesting points here. Can you actually
> > clarify these changes with regard to parts of the official shapefile
> > spec, or have they been found purely through experimentation?
> > ATB,
> > Mark.
> Hi Mark,
> I do still have to figure out, if there are public specs for this. All
> I've found is, that attributes should be in data base files which are in
> dBase format
> (http://www.esri.com/library/whitepapers/pdfs/shapefile.pdf). From the
> analysis of the file (and Wikipedia:
> http://en.wikipedia.org/wiki/Shapefile), it seems that this should be
> dBase III. I do not have any evidence that there is a public spec for
> dBase III.
> So all we did is basically gather some experimental data, where ArcGIS
> and gvSIG are our references. The first, because ESRI introduced the
> shape file format and gvSIG, because it is the desktop environment that
> we encourage our customers to use. Anyway, we have an old
> Borland/Inprise tool ("Database Desktop") here for managing dBase files
> and used it for our tests.
> Peter
Regards,
Chris Hermansen · mailto:chris.hermansen at timberline.ca
tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.840.4625
Timberline Natural Resource Group · http://www.timberline.ca
401 · 958 West 8th Avenue · Vancouver BC · Canada · V5Z 1E5
