[postgis-users] Length of Bigint, Double and Text fields
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Tue Dec 1 09:16:14 PST 2009
Chris Hermansen wrote:
> Peter;
> The canonical description of DBase files seems to be
> http://www.clicketyclick.dk/databases/xbase/format/
Well, first of all, I do not know which dBase version is targeted by ArcGIS.
Second, I doubt the exact values in
http://www.clicketyclick.dk/databases/xbase/format/data_types.html#DATA_TYPES.
 From our tests, both dbase III and dBase IV can handle text fields <=
254 characters (and not < 254).
Further, dBase III can handle numerics with <= 19 digits and not < 18
digits. dBase IV limits this to <= 20 digits.
The above mentioned tool identifies ArcGIS generated files as dBase IV,
in clear conflict on what is said in the above mentioned Wikipedia article.
Cheers,
Peter
> On Tue, 2009-12-01 at 17:28 +0100, Peter Hopfgartner wrote:
>>>> Dear PostGIS devels,
>>>> since we right in the middle of comparing interoperability of shape
>>>> files between some FOSS programs and ArcGIS, we encoutered also the
>>>> following:
>>>> gvSIG chokes on the Bigint as produced by pgsql2shp. Looking at
>>>> ArcGIs generated files, the max length for numbers is 19, compared to
>>>> 20 for integers and 32 for floating points as in pgsql2shp. This
>>>> seems to be confirmed by some Borland tools, when configured for
>>>> dBase III+.
>>>> Another limit seems to be that of text fields, that must be no longer
>>>> then 254. This is the maximum as given by ArcGIS and by the Borland
>>>> tool.
>>>> Another point is Boolean: ArcGIS seems to not allow the creation of
>>>> boolean fields and the Borland Tool ("Database Desktop") says that
>>>> Booleans have a length of 1.
>>>> Regards,
>>>> Peter
>>> Hi Peter,
>>> You've brought up some interesting points here. Can you actually
>>> clarify these changes with regard to parts of the official shapefile
>>> spec, or have they been found purely through experimentation?
>>> ATB,
>>> Mark.
>> Hi Mark,
>> I do still have to figure out, if there are public specs for this. All
>> I've found is, that attributes should be in data base files which are in
>> dBase format
>> (http://www.esri.com/library/whitepapers/pdfs/shapefile.pdf). From the
>> analysis of the file (and Wikipedia:
>> http://en.wikipedia.org/wiki/Shapefile), it seems that this should be
>> dBase III. I do not have any evidence that there is a public spec for
>> dBase III.
>> So all we did is basically gather some experimental data, where ArcGIS
>> and gvSIG are our references. The first, because ESRI introduced the
>> shape file format and gvSIG, because it is the desktop environment that
>> we encourage our customers to use. Anyway, we have an old
>> Borland/Inprise tool ("Database Desktop") here for managing dBase files
>> and used it for our tests.
>> Peter
Dott. Peter Hopfgartner
R3 GIS Srl - GmbH
Via Johann Kravogl-Str. 2
I-39012 Meran/Merano (BZ)
Email: peter.hopfgartner at r3-gis.com
Tel. : +39 0473 494949
Fax  : +39 0473 069902
www  : http://www.r3-gis.com
Venite a trovarci all'ASITA, dal 1 al 4 dicembre a Bari www.asita.it
Besuchen Sie uns bei der Messe ASITA vom 1. bis 4. Dezember in Bari www.asita.it
Visit us at ASITA, from 1st to 4th December in Bari www.asita.it
Type: application/x-dbf
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091201/f3d518b3/attachment.bin>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091201/f3d518b3/attachment.obj>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091201/f3d518b3/attachment.png>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091201/f3d518b3/attachment-0001.bin>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091201/f3d518b3/attachment-0001.png>
