[postgis-users] Cannot install 1.4.0 as non-root user
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Wed Dec 2 07:15:24 PST 2009
Reid Priedhorsky wrote:
Hi Reid,
> I should have clarified. We are using the system Postgres and installing
> PostGIS and GEOS ourselves. In the past (1.3.5), we just compiled
> PostGIS with --prefix, --with-geos, and --with-pgsql* and it worked
> great, just like any other GNU-style "configure" software. Now... ????
> (As an aside, it was also very frustrating that --prefix was silently
> ignored instead of failing at configure time with a coherent error
> message. We spent over an hour tracking that down.)
Thanks for the extra information.
> We're on Ubuntu Hardy.
> * --with-pgsql was needed because we are on Postgres 8.2 but some of the
> 8.3 stuff is also installed because of unrelated dependencies. But in
> 1.4, install wants to put stuff in the 8.3 directories even though
> configure apparently found 8.2 with --with-pgconfig. So I don't see how
> we can install 1.4 even if we did have root.
This sounds like the real problem here. I believe there is a bug in
PostgreSQL 8.2's PGXS Makefile which means that it can pick the wrong
pg_config if you have multiple versions in PATH. The quick fix is to
temporarily override PATH when running "make" on PostGIS so that the
directory containing the pg_config you really want to use is listed
first like this:
PATH=/path/to/8.2/install:$PATH make install
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
