[postgis-users] Making a Polygon from Points
Jan Hartmann
j.l.h.hartmann at uva.nl
Sun Dec 6 02:48:44 PST 2009
Hi David,
I do it like this:
select geometryfromtext
('Polygon ((' || array_to_string
(array
(select x(crd) || ' ' || y(crd)
from points
order by nr
union all
from points
order by nr
limit 1
) || '))',srid
) as the_geom
First put the points in an array, add the first point at the last
position, and convert the array to a GEOMETRY string. You need a column
to orders the points (nr in this case).
Jan
David Potts wrote:
> Hi
> I trying to make a polygon or closed linestring from a list of points.
> I can say something like
> insert into lines(the_geom) select ST_MakeLine(foo.the_geom) from(select
> the_geom from hack where generation=1 and circle=0 ) as foo;
> This results in a open line that runs through all off the points, I am
> trying to generate either a closed line or a polygon.
> Using functions like ST_Polygonize, generate an empty goetry collection.
> Does anybody have any suggestions on how I generate a closed linestring or
> a polygon?
> regards
> Dave.
