[postgis-users] Making a Polygon from Points
David Potts
dave.potts at pinan.co.uk
Sun Dec 6 04:04:28 PST 2009
Thanks Jan,
Worked a treat:-)
Dave.
> Hi David,
> I do it like this:
> select geometryfromtext
> ('Polygon ((' || array_to_string
> (array
> (select x(crd) || ' ' || y(crd)
> from points
> order by nr
> union all
> from points
> order by nr
> limit 1
> ) || '))',srid
> ) as the_geom
> First put the points in an array, add the first point at the last
> position, and convert the array to a GEOMETRY string. You need a column
> to orders the points (nr in this case).
> Jan
> David Potts wrote:
>> Hi
>> I trying to make a polygon or closed linestring from a list of points.
>> I can say something like
>> insert into lines(the_geom) select ST_MakeLine(foo.the_geom)
>> from(select
>> the_geom from hack where generation=1 and circle=0 ) as foo;
>> This results in a open line that runs through all off the points, I am
>> trying to generate either a closed line or a polygon.
>> Using functions like ST_Polygonize, generate an empty goetry
>> collection.
>> Does anybody have any suggestions on how I generate a closed linestring
>> or
>> a polygon?
>> regards
>> Dave.
Any views expressed in this message are those of the individual sender,
except where the sender specifically states them to be the views of the
Pinan Software
