[postgis-users] Suggestion Needed
Paragon Corporation
lr at pcorp.us
Tue Dec 8 11:49:40 PST 2009
Steve,
I think the binaries we have compiled for 8.3 and 8.4 should work with 1.3
since as I recall, I don't think there is any binary dependency between
PostGIS and WKT Raster. So give those experimental ones a try with your 1.3
install. But use the one that says for PostgreSQL 8.3
<http://www.postgis.org/download/windows/experimental.php>
To answer your question -- yes Stack Builder is the safest upgrade path and
PostGIS 1.3 and PostGIS 1.4 can coexist on Windows -- so if you wanted to
give PostGIS 1.4 a try on a new database, you can install that as well and
it won't mess up your existing PostGIS 1.3 installs. I have both running on
my servers in different databases.
Hope that helps,
Regina
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Pierre
Racine
Sent: Tuesday, December 08, 2009 12:17 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Suggestion Needed
Salut Steve,
I would first give it a try with PostGIS 1.3
Let me know if it works.
Pierre
Steve.Toutant at inspq.qc.ca
Sent: 8 décembre 2009 09:47
Cc: 'PostGIS Users Discussion';
I know nothing about compiling, dll'S, etc..
So, I'm willing to try this.
But My current version of postgres is 8.3 and postgis 1.3. I guess I need to
upgrade to postgis 1.4. Should I upgrade postgres also?
Is this procedure is the best and safest way to upgrade postgis?
http://www.postgis.org/download/windows/index.php using stack builder.
I only have one postgres server and users are using it, so I need a safe
procedure to upgrade.
thanks
steve
"Paragon Corporation" <lr at pcorp.us>@postgis.refractions.net
Envoyé par : postgis-users-bounces at postgis.refractions.net
07/12/2009 10:37 PM
Veuillez répondre à
PostGIS Users Discussion <postgis-users at postgis.refractions.net>
A
"'PostGIS Users Discussion'" <postgis-users at postgis.refractions.net>
cc
Objet
FWIW for Windows users, we do have fairly recent compiled WKT Raster as of
December 4th, 2009. Give it a try. I haven't had chance to try WKT Raster
yet, but hopefully this will encourage people to give it a try.
Hope that helps,
Regina
_____
Racine
Sent: Monday, December 07, 2009 3:27 PM
Mukesh,
Sorry for the late answer. You can give a try to WKT Raster. You will have
to compile it though. Loading Geotiff should then be straightforward using
gdal2wktraster.py.
Pierre
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of mukesh
karanwal
Sent: 25 novembre 2009 06:30
Hi..
thanks for the reply.
i did it but still it is showing the same error!
I actually want to store a Geotiff file in the databse, could you please
tell, is there any other way to do this? or where am i doing mistake, if
any?
Thanks
--- On Tue, 11/24/09, Luigi Castro Cardeles <luigi.cardeles at gmail.com>
wrote:
From: Luigi Castro Cardeles <luigi.cardeles at gmail.com>
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Date: Tuesday, November 24, 2009, 10:17 PM
to "bypass" the password, you can make the .pgpass file and fill that with
your connection params (hostname:port:database_name:user:password).
If you are using windows, the path is: C:\Users\<your user
name>\AppData\Roaming\postgresql\.pgpass
best regards
2009/11/24 mukesh karanwal <mukesh_karanwal at yahoo.com
<http://us.mc459.mail.yahoo.com/mc/compose?to=mukesh_karanwal@yahoo.com> >
Hey Everyone,
I am trying to store raster data in Postgis/PostgrSQL using
"geotiff2pgrstaer.exe". but evertime i get an error that "when making
connection to PostgreSQL: fe_sendauth: no password supplied", though i am
supplying all the information.
The command i am giving is like:
C:\..> geotiff2pgraster -h localhost -p 5432 -d postgis -U postgres -P
<mypassword> data.tif(strored at this location only) tablename
Kindly tell the remedy for the above problem and also is there any other way
out to store raster data until now?
Thanks in anticipation
With Regards,
Mukesh
postgis-users mailing list
<http://us.mc459.mail.yahoo.com/mc/compose?to=postgis-users@postgis.refracti
ons.net>
http://postgis.refractions.net/mailman/listinfo/postgis-users
-----Inline Attachment Follows-----
ons.net>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091208/459de271/attachment.html>
