[postgis-users] invalid geometry crashes postgres when trying to use buffer
Christophe Diericx christophe.diericx at natuurpunt.be
Thu Dec 10 01:48:00 PST 2009
Thanks a lot, this seems to work fine as a workaround.
Anyone know if this exact problem persists in current versions of
postgis (could be an incentive to upgrade)?
Christophe
-----Oorspronkelijk bericht-----
Van: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] Namens Kevin
Neufeld
Verzonden: woensdag 9 december 2009 18:26
Aan: PostGIS Users Discussion
Onderwerp: Re: [postgis-users] invalid geometry crashes postgres when
Try reducing the precision of your geometry.
PostGIS doesn't actually have a precision reducer function yet, but
ST_SnapToGrid comes close.
-- Kevin
Christophe Diericx wrote:
> Hello everyone,
> Issuing the following query (while trying to repair an invalid
> geometry):
> ** select buffer(ST_GeomFromText('mypoly',32767),0)
> crashes postgresql hard (extract from the postgresql error-log here:
> http://paste.pocoo.org/show/155923/).
> 'mypoly' can be seen here: http://paste.pocoo.org/show/155921/.
> 32767 corresponds to the following proj4 string: "+proj=lcc
> +lat_1=49.8333333333 +lat_2=51.1666666667 +lat_0=90
> ++lon_0=4.3569397222
> +x_0=150000.01256 +y_0=5400088.4378 +ellps=intl
> +towgs84=81,120,129,0,0,0,0 +units=m +no_defs"
> Some more information about my setup:
> -- select postgis_full_version()
> "POSTGIS="1.3.5" GEOS="3.1.0-CAPI-1.5.0" PROJ="Rel. 4.6.0, 21 Dec
2007"
> USE_STATS"
> -- select version()
> "PostgreSQL 8.3.7 on i486-pc-linux-gnu, compiled by GCC cc (GCC) 4.2.4
> (Ubuntu 4.2.4-1ubuntu3)"
> Is this a known issue and is this fixed in later builds?
> Does anyone have an idea for a workaround with my current versions?
> Thanks in advance for all reactions!
> Christophe
> postgis-users mailing list
