[postgis-users] invalid geometry crashes postgres when trying to use buffer
Kevin Neufeld kneufeld at refractions.net
Thu Dec 10 10:03:57 PST 2009
I can't duplicate your crash running the current release.
                                 postgis_full_version
  POSTGIS="1.4.0" GEOS="3.1.1-CAPI-1.6.0" PROJ="Rel. 4.6.1, 21 August 2008" USE_STATS
(1 row)
-- Kevin
Christophe Diericx wrote:
> Thanks a lot, this seems to work fine as a workaround.
> Anyone know if this exact problem persists in current versions of
> postgis (could be an incentive to upgrade)?
> Christophe
> -----Oorspronkelijk bericht-----
> Van: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] Namens Kevin
> Neufeld
> Verzonden: woensdag 9 december 2009 18:26
> Aan: PostGIS Users Discussion
> Onderwerp: Re: [postgis-users] invalid geometry crashes postgres when
> Try reducing the precision of your geometry.
> PostGIS doesn't actually have a precision reducer function yet, but
> ST_SnapToGrid comes close.
> -- Kevin
>> Hello everyone,
>> Issuing the following query (while trying to repair an invalid
>> geometry):
>> ** select buffer(ST_GeomFromText('mypoly',32767),0)
>> crashes postgresql hard (extract from the postgresql error-log here:
>> http://paste.pocoo.org/show/155923/).
>> 'mypoly' can be seen here: http://paste.pocoo.org/show/155921/.
>> 32767 corresponds to the following proj4 string: "+proj=lcc
>> +lat_1=49.8333333333 +lat_2=51.1666666667 +lat_0=90
>> ++lon_0=4.3569397222
>> +x_0=150000.01256 +y_0=5400088.4378 +ellps=intl
>> +towgs84=81,120,129,0,0,0,0 +units=m +no_defs"
>> Some more information about my setup:
>> -- select postgis_full_version()
>> "POSTGIS="1.3.5" GEOS="3.1.0-CAPI-1.5.0" PROJ="Rel. 4.6.0, 21 Dec
> 2007"
>> USE_STATS"
>> -- select version()
>> "PostgreSQL 8.3.7 on i486-pc-linux-gnu, compiled by GCC cc (GCC) 4.2.4
>> (Ubuntu 4.2.4-1ubuntu3)"
>> Is this a known issue and is this fixed in later builds?
>> Does anyone have an idea for a workaround with my current versions?
>> Thanks in advance for all reactions!
>> Christophe
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
