[postgis-users] how obtain the interior parcels
Fsalas
fsalas at geocuba.cu
Thu Dec 10 12:13:52 PST 2009
Thanks , Fred.
Yes, I need the list of island polygons i use the ST_NumInteriorRings(), ...
but only obtain the number , and i need obtain the list of feature island.
How resolve this?
regards , salas
-----Original Message-----
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Date: Thu, 10 Dec 2009 19:48:17 +0000
Subject: Re: [postgis-users] how obtain the interior parcels
Hi Salas,
are "interior parcels" islands ?
ST_NumInteriorRings(geometry)
Return the number of interior rings of the first polygon in the geometry.
Return NULL if there is no polygon in the geometry.
ST_NumInteriorRing(geometry)
Synonym to NumInteriorRings(geometry). The OpenGIS specs are ambiguous about
the exact function naming, so we provide both spellings.
ST_InteriorRingN(geometry,integer)
Return the N'th interior ring of the polygon geometry. Return NULL if the
geometry is not a polygon or the given N is out of range.
Fred.
On Thu, Dec 10, 2009 at 7:35 PM, Fsalas <fsalas at geocuba.cu> wrote:
I have a table parcels , and I need obtain the list of the only interior
parcels, the parcels is not overlap.
I test ST_Contains(), ST_Intersects() but the result is not correct.
Salas.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091210/eb062d06/attachment.html>
