[postgis-users] how obtain the interior parcels
Fred Lehodey
lehodey at gmail.com
Fri Dec 11 07:58:18 PST 2009
Hi Salas,
not sure this is the better way, but.. ;-)
... (you need POLYGONs, use ST_Dump() if MULTIPOLYGONs)
you can try something like this:
SELECT ST_InteriorRingN((the_geom),s)
FROM your_parcels , generate_series(1,(SELECT
max(ST_NumInteriorRing(the_geom)) FROM your_parcels)) s
WHERE ST_NumInteriorRing(the_geom) > 0
AND ST_InteriorRingN(the_geom,s) IS NOT NULL
Fred...
On Thu, Dec 10, 2009 at 8:13 PM, Fsalas <fsalas at geocuba.cu> wrote:
> Thanks , Fred.
> Yes, I need the list of island polygons i use the ST_NumInteriorRings(),
> ... but only obtain the number , and i need obtain the list of feature
> island.
> How resolve this?
> regards , salas
> -----Original Message-----
> From: Fred Lehodey <lehodey at gmail.com>
> To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> Date: Thu, 10 Dec 2009 19:48:17 +0000
> Subject: Re: [postgis-users] how obtain the interior parcels
> Hi Salas,
> are "interior parcels" islands ?
> ST_NumInteriorRings(geometry)
> Return the number of interior rings of the first polygon in the geometry.
> Return NULL if there is no polygon in the geometry.
> ST_NumInteriorRing(geometry)
> Synonym to NumInteriorRings(geometry). The OpenGIS specs are ambiguous
> about the exact function naming, so we provide both spellings.
> ST_InteriorRingN(geometry,integer)
> Return the N'th interior ring of the polygon geometry. Return NULL if the
> geometry is not a polygon or the given N is out of range.
> Fred.
> On Thu, Dec 10, 2009 at 7:35 PM, Fsalas <fsalas at geocuba.cu> wrote:
>> Hi,
>> I have a table parcels , and I need obtain the list of the only interior
>> parcels, the parcels is not overlap.
>> I test ST_Contains(), ST_Intersects() but the result is not correct.
>> Salas.
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091211/48a4002b/attachment.html>
