[postgis-users] how obtain the interior parcels
fsalas fsalas at geocuba.cu
Thu Dec 17 08:55:58 PST 2009
Hi, Fred
I tested your solution but as you can see en the picture , only select a few interior parcels , My question is
Why Do not select the other interior parcels?
Thanks
Salas
     MSc Francisco D. Salas Rosette
      Director Agencia I+D Aplicado a la Geomática
  ----- Original Message -----
  To: PostGIS Users Discussion
  Sent: Friday, December 11, 2009 9:58 AM
  Subject: Re: [postgis-users] how obtain the interior parcels
  Hi Salas,
  not sure this is the better way, but.. ;-)
  ... (you need POLYGONs, use ST_Dump() if MULTIPOLYGONs)
  you can try something like this:
  SELECT ST_InteriorRingN((the_geom),s)
  FROM your_parcels , generate_series(1,(SELECT max(ST_NumInteriorRing(the_geom)) FROM your_parcels)) s
   WHERE ST_NumInteriorRing(the_geom) > 0
  AND ST_InteriorRingN(the_geom,s) IS NOT NULL
  Fred...
  On Thu, Dec 10, 2009 at 8:13 PM, Fsalas <fsalas at geocuba.cu> wrote:
    Thanks , Fred.
    Yes, I need the list of island polygons i use the ST_NumInteriorRings(), ... but only obtain the number , and i need obtain the list of feature island.
    How resolve this?
    regards , salas
      -----Original Message-----
      To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
      Date: Thu, 10 Dec 2009 19:48:17 +0000
      Hi Salas,
      are "interior parcels" islands ?
        ST_NumInteriorRings(geometry)
        Return the number of interior rings of the first polygon in the geometry. Return NULL if there is no polygon in the geometry.
        ST_NumInteriorRing(geometry)
        Synonym to NumInteriorRings(geometry). The OpenGIS specs are ambiguous about the exact function naming, so we provide both spellings.
        ST_InteriorRingN(geometry,integer)
        Return the N'th interior ring of the polygon geometry. Return NULL if the geometry is not a polygon or the given N is out of range.
      Fred.
      On Thu, Dec 10, 2009 at 7:35 PM, Fsalas <fsalas at geocuba.cu> wrote:
        I have a table parcels , and I need obtain the list of the only interior parcels, the parcels is not overlap.
        I test ST_Contains(), ST_Intersects() but the result is not correct.
        Salas.
        postgis-users mailing list
        http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091217/0067ad08/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091217/0067ad08/attachment.jpg>
Name: interiores nivel3.jpg
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091217/0067ad08/attachment-0001.jpg>
