[postgis-users] how obtain the interior parcels
Havard Tveite havard.tveite at umb.no
Thu Dec 17 09:15:45 PST 2009
Dear Salas,
What is your definition of interior?
 From the picture, it looks as if all your interior parcels
are selected (shown in purple).  Could you point out any
interior parcels that are not selected?
Håvard
fsalas wrote:
> Hi, Fred
> I tested your solution but as you can see en the picture , only select a
> few interior parcels , My question is
> Why Do not select the other interior parcels?
> Thanks
> Salas
> 	MSc Francisco D. Salas Rosette
> Director Agencia I+D Aplicado a la Geomática
>     ----- Original Message -----
>     *From:* Fred Lehodey <mailto:lehodey at gmail.com>
>     *To:* PostGIS Users Discussion
>     <mailto:postgis-users at postgis.refractions.net>
>     *Sent:* Friday, December 11, 2009 9:58 AM
>     *Subject:* Re: [postgis-users] how obtain the interior parcels
>     Hi Salas,
>     not sure this is the better way, but.. ;-)
>     ... (you need POLYGONs, use ST_Dump() if MULTIPOLYGONs)
>     you can try something like this:
>     SELECT ST_InteriorRingN((the_geom),s)
>     FROM your_parcels , generate_series(1,(SELECT
>     max(ST_NumInteriorRing(the_geom)) FROM your_parcels)) s
>      WHERE ST_NumInteriorRing(the_geom) > 0
>     AND ST_InteriorRingN(the_geom,s) IS NOT NULL
>     Fred...
>     On Thu, Dec 10, 2009 at 8:13 PM, Fsalas <fsalas at geocuba.cu
>     <mailto:fsalas at geocuba.cu>> wrote:
>         Thanks , Fred.
>         Yes, I need the list of island polygons i use the
>         ST_NumInteriorRings(), ... but only obtain the number , and i
>         need obtain the list of feature island.
>         How resolve this?
>         regards , salas
>             -----Original Message-----
>             From: Fred Lehodey <lehodey at gmail.com
>             <mailto:lehodey at gmail.com>>
>             To: PostGIS Users Discussion
>             <postgis-users at postgis.refractions.net
>             <mailto:postgis-users at postgis.refractions.net>>
>             Date: Thu, 10 Dec 2009 19:48:17 +0000
>             Subject: Re: [postgis-users] how obtain the interior parcels
>             Hi Salas,
>             are "interior parcels" islands ?
>             ST_NumInteriorRings(geometry)
>                 Return the number of interior rings of the first polygon
>                 in the geometry. Return NULL if there is no polygon in
>                 the geometry.
>             ST_NumInteriorRing(geometry)
>                 Synonym to NumInteriorRings(geometry). The OpenGIS specs
>                 are ambiguous about the exact function naming, so we
>                 provide both spellings.
>             ST_InteriorRingN(geometry,integer)
>                 Return the N'th interior ring of the polygon geometry.
>                 Return NULL if the geometry is not a polygon or the
>                 given N is out of range.
>             Fred.
>             On Thu, Dec 10, 2009 at 7:35 PM, Fsalas <fsalas at geocuba.cu
>                 Hi,
>                 I have a table parcels , and I need obtain the list of
>                 the only interior parcels, the parcels is not overlap.
>                 I test ST_Contains(), ST_Intersects() but the result is
>                 not correct.
>                 Salas.
>                 _______________________________________________
>                 postgis-users mailing list
>                 http://postgis.refractions.net/mailman/listinfo/postgis-users
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
