[postgis-users] Weird GEOS problem
George Vlahakis g.vlahakis at telenavis.com
Fri Dec 11 03:14:49 PST 2009
Ok thanks, I used to use npgsql but for spatial queries and binary
geometry retrieval I found it the opposite. It has been some time, but I
will try it.
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Emilie Laffray
Sent: Friday, December 11, 2009 1:13 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Weird GEOS problem
2009/12/11 George Vlahakis <g.vlahakis at telenavis.com>
Hi all,
Probably nobody has seen this, but on a particular machine (Win XP)
every 2-3 hours or so I am getting the following error:
System.Data.Odbc.OdbcException: ERROR [XX000] ERROR: Error creating GEOS
Coordinate Sequence; Error while executing the query
I might be wrong but you are using .NET?
If it is indeed the case, I would suggest dropping the use of odbc, and
use npgsql which provides a direct connection to the database. It should
give you better performance, and maybe extra stability.
Emilie Laffray
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091211/0273e34d/attachment.html>
