[postgis-users] Reverse X and Y coordinates?
Kevin Neufeld
kneufeld at refractions.net
Fri Dec 18 19:02:53 PST 2009
What about rotating about the line y=x?
SELECT ST_AsText(ST_Affine(
column1,
cos(pi()/2), sin(pi()/2),
sin(pi()/2), cos(pi()/2),
0, 0
FROM (VALUES
('POINT(4 3)'),
('LINESTRING(1 2, 59 34, -9 3)'),
('POLYGON (( 2 13, 6 12, 4 8, 2 7, 2 13 ),
( 4 12, 3 10, 3 9, 4 10, 4 12 ))')
) a;
st_astext
POINT(3 4)
LINESTRING(2 1,34 59,3 -9)
POLYGON((13 2,12 6,8 4,7 2,13 2),(12 4,10 3,9 3,10 4,12 4))
(3 rows)
-- Kevin
Anthony McClure wrote:
> Good day,
> I have a problem that I cannot find a solution to. I have the X and Y
> coordinates reversed in the geometries within my database. I need the
> X's to become Y's and the Y's to become X's. The geometries are all
> polygons or multi-polygons. Is there anything within PostGIS I can
> execute SQL wise to do this?
> The only other thing I can think of is to write code to go through all
> of the points and reverse them manually which obviously I am hoping to
> avoid.
> Thanks for the help,
> Anthony
> This email, and any attachments thereto, is intended
> only for use by the addressee(s) named herein and may
> contain legally privileged and/or confidential information.
> If you are not the intended recipient of this email, you
> are hereby notified that any dissemination, distribution
> or copying of this email, and any attachments thereto,
> is strictly prohibited. If you have received this e-mail in
> error, please immediately and permanently delete the
> original and any copy of any email and any printout
> thereof.
> postgis-users mailing list
