[postgis-users] Problem trying to import data from wetlands.fws.gov
Kevin Neufeld
kneufeld at refractions.net
Sat Dec 19 10:02:47 PST 2009
It looks like your insert statement is missing the proj4 text string.
PostGIS doesn't use the spatialreference wkt at all, rather, it
delegates it's transformations to proj4.
Bryan Montgomery wrote:
> Hi,
> We've bene trying to import shape files from the website here. (RI is
> relatively small). I can display the shape files on udig, but have not
> been able to use shp2pgsql to import them an make sense of it.
> I tried running INSERT into spatial_ref_sys (srid, auth_name,
> auth_srid, proj4text, srtext)
> values ( 924, 'sr-org', 24, '',
> 'PROJCS["NAD_1983_Albers",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.017453292519943295]],PROJECTION["Albers"],PARAMETER["False_Easting",00000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-96.0],PARAMETER["Standard_Parallel_1",29.5],PARAMETER["Standard_Parallel_2",45.5],PARAMETER["Latitude_Of_Origin",23.0],UNIT["Meter",1.0]]');
> and use that as the srid of the imported data. Trying to st_transofrm
> that to 4326 or 32015 on windows with postgresql 8.4.1 crashed the
> server. We've also run it on 8.2 on linux - which doesn't die.
> However, the results are essentially garbage. I assume there is
> something (probably simple) that we are missing. Can someon point us
> in the right direction to get this converted?
> From what I can tell, udig sees thespatial reference as posted below.
> I used a link from
> http://spatialreference.org/ref/sr-org/24/postgis/ as the basis for
> creating the srid above.
> SPHEROID["GRS_1980", 6378137.0, 298.257222101]],
> PRIMEM["Greenwich", 0.0],
> UNIT["degree", 0.017453292519943295],
> AXIS["Lon", EAST],
> AXIS["Lat", NORTH]],
> PROJECTION["Albers_Conic_Equal_Area"],
> PARAMETER["central_meridian", -96.0],
> PARAMETER["latitude_of_origin", 23.0],
> PARAMETER["standard_parallel_1", 29.5],
> PARAMETER["false_easting", 0.0],
> PARAMETER["false_northing", 0.0],
> PARAMETER["standard_parallel_2", 45.5],
> UNIT["m", 1.0],
> AXIS["x", EAST],
> AXIS["y", NORTH]]
> Thanks,
> Bryan.
> postgis-users mailing list
