[postgis-users] postgis installation problem
Devrim GÜNDÜZ
devrim at gunduz.org
Mon Dec 28 20:19:37 PST 2009
On Tue, 2009-12-29 at 04:06 +0000, Muhammad Adnan wrote:
> /usr/local/pgsql/bin/psql -d test
> -f /usr/share/postgresql/8.4/contrib/postgis.sql
<snip>
> I am installing the following packages on ubuntu 9.10
> postgresql-8.4.1
So your are not using the psql that is provided by PostgreSQL package
itself, which is causing confusions. Either use distro's PostgreSQL, or
compile PostGIS from sources, or edit postgis.sql so that it will point
to correct $libdir.
Devrim GÜNDÜZ, RHCE
Command Prompt - http://www.CommandPrompt.com
devrim~gunduz.org, devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
http://www.gunduz.org Twitter: http://twitter.com/devrimgunduz
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091229/50eea5c6/attachment.pgp>
