[postgis-users] postgis installation problem
pcreso at pcreso.com
Mon Dec 28 20:50:27 PST 2009
Or install from packages built for your distribution, in which case no compilation is necessary.
This should work for most common Linux distributions, which one are you using?
Brent Wood
--- On Tue, 12/29/09, Devrim GÜNDÜZ <devrim at gunduz.org> wrote:
> From: Devrim GÜNDÜZ <devrim at gunduz.org>
> Subject: Re: [postgis-users] postgis installation problem
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Date: Tuesday, December 29, 2009, 5:19 PM
> On Tue, 2009-12-29 at 04:06 +0000,
> Muhammad Adnan wrote:
> > /usr/local/pgsql/bin/psql -d test
> > -f /usr/share/postgresql/8.4/contrib/postgis.sql
> <snip>
> > I am installing the following packages on ubuntu 9.10
> > postgresql-8.4.1
> So your are not using the psql that is provided by
> PostgreSQL package
> itself, which is causing confusions. Either use distro's
> PostgreSQL, or
> compile PostGIS from sources, or edit postgis.sql so that
> it will point
> to correct $libdir.
> Devrim GÜNDÜZ, RHCE
> Command Prompt - http://www.CommandPrompt.com
> devrim~gunduz.org, devrim~PostgreSQL.org,
> devrim.gunduz~linux.org.tr
> http://www.gunduz.org Twitter: http://twitter.com/devrimgunduz
> -----Inline Attachment Follows-----
> postgis-users mailing list
