[postgis-users] Re: Test the Future (GEOS 3.1RC2)
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Tue Feb 3 10:05:05 PST 2009
Bruce Rindahl wrote:
> Using WinXP SP3 and MingW. Compiled and installed GEOS-3.1.0rc2.
> Compiled and installed PostgreSQL-8.3.5.
> I got the following errors when running configure postGIS-1.1.0SVN:
> configure: error: the PGXS Makefile
> c:/Postgresql/8.3/lib/pgxs/src/makefiles/pgxs.mk cannot be found. Please
> install the PostgreSQL server development packages and re-run configure.
> What did I miss?
> Thanks
> Bruce
Hi Bruce,
I'd say that configure has picked up the wrong pg_config from the system
path - make sure you explicitly choose the MingW pg_config using the
--with-pgconfig=/c/path/to/mingw/pg_config option.
HTH,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
