[postgis-users] Re: Test the Future (GEOS 3.1RC2)
Bruce Rindahl
rindahl at lrcwe.com
Tue Feb 3 10:58:46 PST 2009
Sorry - I just found the thread:
http://postgis.refractions.net/pipermail/postgis-devel/2009-January/004693.html
Has this been resolved?
Bruce
Bruce Rindahl wrote:
> I have the --with-pg_config and --with-projdir define so configure
> works. Make gives the following error:
> make[1]: Entering directory `/home/bruce/postgis-svn/loader'
> gcc -g -O2 -DDLL_EXPORT -DPIC -Wall -Wmissing-prototypes -liconv -lm
> stringbuffer.o shpopen.o dbfopen.o shp2pgsql-core.o shp2pgsql-cli.o
> ../liblwgeom/liblwgeom.a -o shp2pgsql-cli.exe
> shp2pgsql-core.o: In function `pgis_logf':
> C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:177:
> undefined reference to `vasprintf'
> shp2pgsql-core.o: In function `DropTable':
> C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1518:
> undefined reference to `asprintf'
> C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1538:
> C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1510:
> C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1530:
> shp2pgsql-core.o: In function `utf8':
> C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1677:
> undefined reference to `libiconv_open'
> C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1695:
> undefined reference to `libiconv'
> C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1701:
> undefined reference to `libiconv_close'
> shp2pgsql-core.o: In function `LoadData':
> C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:739:
> C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:744:
> collect2: ld returned 1 exit status
> make[1]: *** [shp2pgsql-cli.exe] Error 1
> make[1]: Leaving directory `/home/bruce/postgis-svn/loader'
> make: *** [loaderdumper] Error 2
> Any suggestions here?
> Thanks!
> Bruce
>>> Using WinXP SP3 and MingW. Compiled and installed GEOS-3.1.0rc2.
>>> Compiled and installed PostgreSQL-8.3.5.
>>> I got the following errors when running configure postGIS-1.1.0SVN:
>>> configure: error: the PGXS Makefile
>>> c:/Postgresql/8.3/lib/pgxs/src/makefiles/pgxs.mk cannot be found.
>>> Please install the PostgreSQL server development packages and re-run
>>> configure.
>>> What did I miss?
>>> Thanks
>>> Bruce
>> Hi Bruce,
>> I'd say that configure has picked up the wrong pg_config from the
>> system path - make sure you explicitly choose the MingW pg_config
>> using the --with-pgconfig=/c/path/to/mingw/pg_config option.
>> HTH,
>> Mark.
> postgis-users mailing list
