[postgis-users] Re: Test the Future (GEOS 3.1RC2)
Paul Ramsey pramsey at opengeo.org
Tue Feb 3 11:20:20 PST 2009
No, that's as far as the thread got. For the short term, edit your
makefile and remove the shp2pgsql-cli target and any other target that
errors out on you. The old shp2pgsql is still there and will work
fine.
P.
On Tue, Feb 3, 2009 at 10:58 AM, Bruce Rindahl <rindahl at lrcwe.com> wrote:
> Sorry - I just found the thread:
> http://postgis.refractions.net/pipermail/postgis-devel/2009-January/004693.html
> Has this been resolved?
> Bruce
> Bruce Rindahl wrote:
>> I have the --with-pg_config and --with-projdir define so configure works.
>>  Make gives the following error:
>> make[1]: Entering directory `/home/bruce/postgis-svn/loader'
>> gcc -g -O2  -DDLL_EXPORT -DPIC  -Wall -Wmissing-prototypes -liconv -lm
>> stringbuffer.o shpopen.o dbfopen.o shp2pgsql-core.o shp2pgsql-cli.o
>> ../liblwgeom/liblwgeom.a -o shp2pgsql-cli.exe
>> shp2pgsql-core.o: In function `pgis_logf':
>> C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:177: undefined
>> reference to `vasprintf'
>> shp2pgsql-core.o: In function `DropTable':
>> C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1518: undefined
>> reference to `asprintf'
>> C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1538: undefined
>> C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1510: undefined
>> C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1530: undefined
>> shp2pgsql-core.o: In function `utf8':
>> C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1677: undefined
>> reference to `libiconv_open'
>> C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1695: undefined
>> reference to `libiconv'
>> C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1701: undefined
>> reference to `libiconv_close'
>> shp2pgsql-core.o: In function `LoadData':
>> C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:739: undefined
>> C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:744: undefined
>> collect2: ld returned 1 exit status
>> make[1]: *** [shp2pgsql-cli.exe] Error 1
>> make[1]: Leaving directory `/home/bruce/postgis-svn/loader'
>> make: *** [loaderdumper] Error 2
>> Any suggestions here?
>> Thanks!
>> Bruce
>>>> Using WinXP SP3 and MingW.  Compiled and installed GEOS-3.1.0rc2.
>>>>  Compiled and installed PostgreSQL-8.3.5.
>>>> I got the following errors when running configure  postGIS-1.1.0SVN:
>>>> configure: error: the PGXS Makefile
>>>> c:/Postgresql/8.3/lib/pgxs/src/makefiles/pgxs.mk cannot be found. Please
>>>> install the PostgreSQL server development packages and re-run configure.
>>>> What did I miss?
>>>> Thanks
>>>> Bruce
>>> Hi Bruce,
>>> I'd say that configure has picked up the wrong pg_config from the system
>>> path - make sure you explicitly choose the MingW pg_config using the
>>> --with-pgconfig=/c/path/to/mingw/pg_config option.
>>> HTH,
>>> Mark.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
