[postgis-users] Basic question #3 schemas
Kevin Neufeld
kneufeld at refractions.net
Wed Feb 18 20:09:42 PST 2009
It's highly recommended to use schemas. No, there aren't any concerns
with speed or indexing that I'm aware of.
I have about 50 schemas in a large 150GB database at the moment. Each
schema is like a subdirectory of tables. Once you're in the habit to
schema-qualify your tables or get familiar with using search_paths, it's
exactly like using the single public schema ... except now your data is
organized.
Personally, I take it a step further. I never store anything in the
public schema - I reserve that for PostGIS and PostgreSQL modules like
cube or tsearch. It makes upgrading crazy easy because I can pg_dump
everything EXCEPT the public schema into a new PostGIS install. Besides
having hundreds of tables, I also have many custom plpgsql functions.
If I stored them in public, they would get mixed up with the 600+
PostGIS functions. I would need to sort them all out when trying to
pg_dump everything except PostGIS ... now that's would be a pain.
Cheers,
Kevin
Ben Madin wrote:
> And finally,
> following on from my previous questions, I have a database at the
> moment with relatively static gis data and a large amount of content
> being added regularly. I'm learning about how Schema's work, and it
> would seem to me that I might see some management benefits from
> putting my GIS data into a schema on it's own, so I can pg_dump only
> my general work schema regularly, and the gis schema only after I've
> made changes (probably only every few months). This would help to
> avoid the current risk of not backing up tables because I added them
> to the database, but not to the -t element of pg_dump. It would also
> help because we backup nightly, and then transfer the database
> (currently around 54MB) across the internet to an offsite server. I'm
> guessing with out the GIS component, we'd be talking about < 2MB.
> Given the size of the GIS component, this would be attractive... but
> are there implications for speed? Indexing? any good reasons not to do
> this?
> cheers
> Ben
