AW: [postgis-users] ST_AsSVG crashes with large/complex geometries
Hugentobler Marco
marco.hugentobler at karto.baug.ethz.ch
Thu Feb 19 05:45:53 PST 2009
Hi Mike
It would be helpfull if you could send a sample geometry (maybe directly to me in order to not give advice for easy dos attacks). It may not only be the size but also the complexity or the way a geometry is composed.
Regards,
Marco
-----Ursprüngliche Nachricht-----
Von: postgis-users-bounces at postgis.refractions.net im Auftrag von Mike Leahy
Gesendet: Do 19.02.2009 14:32
An: postgis-users at postgis.refractions.net
Betreff: [postgis-users] ST_AsSVG crashes with large/complex geometries
Hello list,
I'm wondering if anyone has run into issues with st_assvg locking up
postgresql. I have an application that generates svg from unioned sets
of geometries. So far it has been working pretty well, except I just
tested it with very large sets of geometries, and it invariably locks up
the backend database without any errors etc. I could send a sample
geometry if that would help, but I think this can probably be done with
any dataset. I've verified that the problem is not with st_union, as it
outputs a geometry just fine...it's only when it gets to st_assvg does
it freeze things...there is no CPU activity. I do see this in the pg_log:
*** glibc detected *** postgres: postgres testdb [local] SELECT:
realloc(): invalid next size: 0x000000000220f410 ***
Am I just expecting too much of the st_assvg function, or is this
something that might be fixable?
Thanks for any advice,
Mike
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
