[postgis-users] troubles installing PostGIS
Geoffrey Fairchild
geoffairchild at gmail.com
Mon Feb 23 00:20:41 PST 2009
Output folder: C:\Users\*****\AppData\Local\Temp\postgis_installer
UserName=postgres
Password=**********
Port=5432
Checking for existing PostGIS installation...
Output folder: C:\Program Files (x86)\PostgreSQL\8.3\bin
Skipped: libiconv-2.dll
Extract: libgeos-3-0-3.dll... 100%
Extract: libgeos_c-1.dll... 100%
Extract: libproj.dll... 100%
Extract: pgsql2shp.exe... 100%
Extract: shp2pgsql.exe... 100%
Output folder: C:\Program Files (x86)\PostgreSQL\8.3\doc\contrib
Extract: README.pgsql2shp... 100%
Extract: README.postgis... 100%
Extract: README.shp2pgsql... 100%
(x86)\PostgreSQL\8.3\doc\contrib\html\postgis
Extract: postgis.html... 100%
Extract: style.css... 100%
(x86)\PostgreSQL\8.3\doc\contrib\html\postgis\jdbc
Extract: allclasses-frame.html... 100%
Extract: allclasses-noframe.html... 100%
Extract: constant-values.html... 100%
Extract: deprecated-list.html... 100%
Extract: help-doc.html... 100%
Extract: index-all.html... 100%
Extract: index.html... 100%
Extract: overview-frame.html... 100%
Extract: overview-summary.html... 100%
Extract: overview-tree.html... 100%
Extract: package-list... 100%
Extract: serialized-form.html... 100%
Extract: stylesheet.css... 100%
(x86)\PostgreSQL\8.3\doc\contrib\html\postgis\jdbc\examples
Extract: package-frame.html... 100%
Extract: package-summary.html... 100%
Extract: package-tree.html... 100%
Extract: Test.html... 100%
Extract: TestAutoregister.html... 100%
Extract: TestBoxes.html... 100%
Extract: TestJava2d.EventHandler.html... 100%
Extract: TestJava2d.GisCanvas.html... 100%
Extract: TestJava2d.html... 100%
Extract: TestParser.html... 100%
Extract: TestServer.html... 100%
Extract: VersionPrinter.html... 100%
(x86)\PostgreSQL\8.3\doc\contrib\html\postgis\jdbc\org\postgis
Extract: ComposedGeom.html... 100%
Extract: DriverWrapper.html... 100%
Extract: DriverWrapper.TypesAdder.html... 100%
Extract: DriverWrapper.TypesAdder72.html... 100%
Extract: DriverWrapper.TypesAdder74.html... 100%
Extract: DriverWrapper.TypesAdder80.html... 100%
Extract: DriverWrapperAutoprobe.html... 100%
Extract: DriverWrapperLW.html... 100%
Extract: Geometry.html... 100%
Extract: GeometryCollection.html... 100%
Extract: LinearRing.html... 100%
Extract: LineString.html... 100%
Extract: MultiLineString.html... 100%
Extract: MultiPoint.html... 100%
Extract: MultiPolygon.html... 100%
Extract: PGbox2d.html... 100%
Extract: PGbox3d.html... 100%
Extract: PGboxbase.html... 100%
Extract: PGgeometry.html... 100%
Extract: PGgeometryLW.html... 100%
Extract: Point.html... 100%
Extract: PointComposedGeom.html... 100%
Extract: Polygon.html... 100%
Extract: Version.html... 100%
(x86)\PostgreSQL\8.3\doc\contrib\html\postgis\jdbc\org\postgis\binary
Extract: BinaryParser.html... 100%
Extract: BinaryWriter.html... 100%
Extract: ByteGetter.BinaryByteGetter.html... 100%
Extract: ByteGetter.html... 100%
Extract: ByteGetter.StringByteGetter.html... 100%
Extract: ByteSetter.BinaryByteSetter.html... 100%
Extract: ByteSetter.html... 100%
Extract: ByteSetter.StringByteSetter.html... 100%
Extract: ValueGetter.html... 100%
Extract: ValueGetter.NDR.html... 100%
Extract: ValueGetter.XDR.html... 100%
Extract: ValueSetter.html... 100%
Extract: ValueSetter.NDR.html... 100%
Extract: ValueSetter.XDR.html... 100%
(x86)\PostgreSQL\8.3\doc\contrib\html\postgis\jdbc\org\postgis\java2d
Extract: Java2DWrapper.html... 100%
Extract: PGShapeGeometry.html... 100%
Extract: ShapeBinaryParser.html... 100%
(x86)\PostgreSQL\8.3\doc\contrib\html\postgis\jdbc\resources
Extract: inherit.gif
Output folder: C:\Program Files (x86)\PostgreSQL\8.3\jdbc
Extract: postgis_1.3.5.jar... 100%
Output folder: C:\Program Files (x86)\PostgreSQL\8.3\lib
Extract: liblwgeom.dll... 100%
Output folder: C:\Program Files (x86)\PostgreSQL\8.3\share\contrib
Extract: lwpostgis.sql... 100%
Extract: spatial_ref_sys.sql... 100%
Output folder: C:\Program Files (x86)\PostgreSQL\8.3\share\contrib\postgis
Extract: lwpostgis_upgrade.sql... 100%
(x86)\PostgreSQL\8.3\share\contrib\postgis\proj
Extract: alaska... 100%
Extract: conus... 100%
Extract: epsg... 100%
Extract: esri... 100%
Extract: esri.extra... 100%
Extract: FL... 100%
Extract: GL27... 100%
Extract: hawaii... 100%
Extract: IGNF... 100%
Extract: MD... 100%
Extract: nad.lst... 100%
Extract: nad27... 100%
Extract: nad83... 100%
Extract: ntf_r93.gsb... 100%
Extract: ntv1_can.dat... 100%
Extract: null... 100%
Extract: nzgd2kgrid0005.gsb... 100%
Extract: other.extra... 100%
Extract: proj_def.dat... 100%
Extract: prvi... 100%
Extract: stgeorge... 100%
Extract: stlrnc... 100%
Extract: stpaul... 100%
Extract: TN... 100%
Extract: WI... 100%
Extract: WO... 100%
Extract: world... 100%
(x86)\PostgreSQL\8.3\share\contrib\postgis\topology
Extract: README... 100%
Extract: topology.sql... 100%
(x86)\PostgreSQL\8.3\share\contrib\postgis\utils
Extract: create_undef.pl... 100%
Extract: postgis_proc_upgrade.pl... 100%
Extract: postgis_restore.pl... 100%
Creating template database...
Loading PLPGSQL language...
Loading PostGIS functions...
Create folder: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PostGIS
1.3.5 for PostgreSQL 8.3
Create shortcut: C:\ProgramData\Microsoft\Windows\Start
Menu\Programs\PostGIS 1.3.5 for PostgreSQL 8.3\PostGIS 1.3.5
Documentation.lnk
Menu\Programs\PostGIS 1.3.5 for PostgreSQL 8.3\PostGIS 1.3.5 JDBC Driver
Documentation.lnk
Created uninstaller: C:\Program Files
(x86)\PostgreSQL\8.3\uninstall-postgis-pg83-1.3.5-1.exe
DataBase=postgis
Creating spatial database...
Completed
Looks like everything besides the error worked just fine. The log just says
"Skipped: libiconv-2.dll" in reference to the error. In fact, I just
thought to open up the installer (thanks to 7-Zip), and I compared the 2
libiconv-2.dll files - the one in the PostgreSQL bin folder and the one in
the PostGIS bin folder. The PostgreSQL file is larger (946kb vs 873kb) and
has a more recent last modified time (1/6/09 vs 12/16/08). I'm guessing
that I want the newer copy anyway, so perhaps skipping over that file isn't
such a bad thing. Why does PostGIS include that file in the first place if
it's included with PostgreSQL?
Geoff
On Mon, Feb 23, 2009 at 1:40 AM, Mark Cave-Ayland <
mark.cave-ayland at siriusit.co.uk> wrote:
> Geoffrey Fairchild wrote:
> I'm installing a clean install of PostgreSQL 8.3.6 on Vista 64 Ultimate.
>> I'm using the stack builder to install PostGIS 1.3.5. PostgreSQL installs
>> just fine. When I use the stack builder to install PostGIS, it downloads
>> just fine, but when I go to install I get this error message:
>> http://i44.tinypic.com/2eojgd0.png (I also attached this screenshot to
>> this email.) I've tried turning off UAC, giving myself full
>> read/write/modify privaleges for that directory, logging into the
>> Administrator account, and nothing works. I just get that error every time.
>> The file it's referencing exists. PostgreSQL is functioning perfectly
>> (I've created tables, inserted data, etc). I tried clicking ignore, and the
>> installer continues and appears to succeed, but that error is worrysome. I
>> just want to make sure I'm not going to have a buggy install. Does anyone
>> have any idea why this happening? Thanks!
>> Geoff
> Hi Geoff,
> I'm afraid I don't have access to Vista in order to find out what is
> happening - all of the development for the current Win32 installer is done
> under Win32.
> There have been some reports of various permissions errors coming up on the
> list, but so far I haven't been able to find out enough information in order
> to determine what is going wrong. Does the NSIS installer log (appears at
> the end of the wizard) provide any useful information at all?
> ATB,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090223/4d957906/attachment.html>
