[postgis-users] troubles installing PostGIS
Geoffrey Fairchild
geoffairchild at gmail.com
Mon Feb 23 06:49:49 PST 2009
Thanks for the help. I hope my troubles will help you guys out. :)
Geoff
On Mon, Feb 23, 2009 at 4:41 AM, Mark Cave-Ayland <
mark.cave-ayland at siriusit.co.uk> wrote:
> Geoffrey Fairchild wrote:
>> Output folder: C:\Users\*****\AppData\Local\Temp\postgis_installer
>> UserName=postgres
>> Password=**********
>> Port=5432
>> Checking for existing PostGIS installation...
>> Output folder: C:\Program Files (x86)\PostgreSQL\8.3\bin
>> Skipped: libiconv-2.dll
>> Extract: libgeos-3-0-3.dll... 100%
>> Extract: libgeos_c-1.dll... 100%
>> Extract: libproj.dll... 100%
>> Extract: pgsql2shp.exe... 100%
>> Extract: shp2pgsql.exe... 100%
>> Output folder: C:\Program Files (x86)\PostgreSQL\8.3\doc\contrib
>> Extract: README.pgsql2shp... 100%
>> Extract: README.postgis... 100%
>> Extract: README.shp2pgsql... 100%
>> (x86)\PostgreSQL\8.3\doc\contrib\html\postgis
>> Extract: postgis.html... 100%
>> Extract: style.css... 100%
>> (x86)\PostgreSQL\8.3\doc\contrib\html\postgis\jdbc
>> Extract: allclasses-frame.html... 100%
>> Extract: allclasses-noframe.html... 100%
>> Extract: constant-values.html... 100%
>> Extract: deprecated-list.html... 100%
>> Extract: help-doc.html... 100%
>> Extract: index-all.html... 100%
>> Extract: index.html... 100%
>> Extract: overview-frame.html... 100%
>> Extract: overview-summary.html... 100%
>> Extract: overview-tree.html... 100%
>> Extract: package-list... 100%
>> Extract: serialized-form.html... 100%
>> Extract: stylesheet.css... 100%
>> (x86)\PostgreSQL\8.3\doc\contrib\html\postgis\jdbc\examples
>> Extract: package-frame.html... 100%
>> Extract: package-summary.html... 100%
>> Extract: package-tree.html... 100%
>> Extract: Test.html... 100%
>> Extract: TestAutoregister.html... 100%
>> Extract: TestBoxes.html... 100%
>> Extract: TestJava2d.EventHandler.html... 100%
>> Extract: TestJava2d.GisCanvas.html... 100%
>> Extract: TestJava2d.html... 100%
>> Extract: TestParser.html... 100%
>> Extract: TestServer.html... 100%
>> Extract: VersionPrinter.html... 100%
>> (x86)\PostgreSQL\8.3\doc\contrib\html\postgis\jdbc\org\postgis
>> Extract: ComposedGeom.html... 100%
>> Extract: DriverWrapper.html... 100%
>> Extract: DriverWrapper.TypesAdder.html... 100%
>> Extract: DriverWrapper.TypesAdder72.html... 100%
>> Extract: DriverWrapper.TypesAdder74.html... 100%
>> Extract: DriverWrapper.TypesAdder80.html... 100%
>> Extract: DriverWrapperAutoprobe.html... 100%
>> Extract: DriverWrapperLW.html... 100%
>> Extract: Geometry.html... 100%
>> Extract: GeometryCollection.html... 100%
>> Extract: LinearRing.html... 100%
>> Extract: LineString.html... 100%
>> Extract: MultiLineString.html... 100%
>> Extract: MultiPoint.html... 100%
>> Extract: MultiPolygon.html... 100%
>> Extract: PGbox2d.html... 100%
>> Extract: PGbox3d.html... 100%
>> Extract: PGboxbase.html... 100%
>> Extract: PGgeometry.html... 100%
>> Extract: PGgeometryLW.html... 100%
>> Extract: Point.html... 100%
>> Extract: PointComposedGeom.html... 100%
>> Extract: Polygon.html... 100%
>> Extract: Version.html... 100%
>> (x86)\PostgreSQL\8.3\doc\contrib\html\postgis\jdbc\org\postgis\binary
>> Extract: BinaryParser.html... 100%
>> Extract: BinaryWriter.html... 100%
>> Extract: ByteGetter.BinaryByteGetter.html... 100%
>> Extract: ByteGetter.html... 100%
>> Extract: ByteGetter.StringByteGetter.html... 100%
>> Extract: ByteSetter.BinaryByteSetter.html... 100%
>> Extract: ByteSetter.html... 100%
>> Extract: ByteSetter.StringByteSetter.html... 100%
>> Extract: ValueGetter.html... 100%
>> Extract: ValueGetter.NDR.html... 100%
>> Extract: ValueGetter.XDR.html... 100%
>> Extract: ValueSetter.html... 100%
>> Extract: ValueSetter.NDR.html... 100%
>> Extract: ValueSetter.XDR.html... 100%
>> (x86)\PostgreSQL\8.3\doc\contrib\html\postgis\jdbc\org\postgis\java2d
>> Extract: Java2DWrapper.html... 100%
>> Extract: PGShapeGeometry.html... 100%
>> Extract: ShapeBinaryParser.html... 100%
>> (x86)\PostgreSQL\8.3\doc\contrib\html\postgis\jdbc\resources
>> Extract: inherit.gif
>> Output folder: C:\Program Files (x86)\PostgreSQL\8.3\jdbc
>> Extract: postgis_1.3.5.jar... 100%
>> Output folder: C:\Program Files (x86)\PostgreSQL\8.3\lib
>> Extract: liblwgeom.dll... 100%
>> Output folder: C:\Program Files (x86)\PostgreSQL\8.3\share\contrib
>> Extract: lwpostgis.sql... 100%
>> Extract: spatial_ref_sys.sql... 100%
>> Output folder: C:\Program Files (x86)\PostgreSQL\8.3\share\contrib\postgis
>> Extract: lwpostgis_upgrade.sql... 100%
>> (x86)\PostgreSQL\8.3\share\contrib\postgis\proj
>> Extract: alaska... 100%
>> Extract: conus... 100%
>> Extract: epsg... 100%
>> Extract: esri... 100%
>> Extract: esri.extra... 100%
>> Extract: FL... 100%
>> Extract: GL27... 100%
>> Extract: hawaii... 100%
>> Extract: IGNF... 100%
>> Extract: MD... 100%
>> Extract: nad.lst... 100%
>> Extract: nad27... 100%
>> Extract: nad83... 100%
>> Extract: ntf_r93.gsb... 100%
>> Extract: ntv1_can.dat... 100%
>> Extract: null... 100%
>> Extract: nzgd2kgrid0005.gsb... 100%
>> Extract: other.extra... 100%
>> Extract: proj_def.dat... 100%
>> Extract: prvi... 100%
>> Extract: stgeorge... 100%
>> Extract: stlrnc... 100%
>> Extract: stpaul... 100%
>> Extract: TN... 100%
>> Extract: WI... 100%
>> Extract: WO... 100%
>> Extract: world... 100%
>> (x86)\PostgreSQL\8.3\share\contrib\postgis\topology
>> Extract: README... 100%
>> Extract: topology.sql... 100%
>> (x86)\PostgreSQL\8.3\share\contrib\postgis\utils
>> Extract: create_undef.pl... 100%
>> Extract: postgis_proc_upgrade.pl... 100%
>> Extract: postgis_restore.pl... 100%
>> Creating template database...
>> Loading PLPGSQL language...
>> Loading PostGIS functions...
>> Create folder: C:\ProgramData\Microsoft\Windows\Start
>> Menu\Programs\PostGIS 1.3.5 for PostgreSQL 8.3
>> Create shortcut: C:\ProgramData\Microsoft\Windows\Start
>> Menu\Programs\PostGIS 1.3.5 for PostgreSQL 8.3\PostGIS 1.3.5
>> Documentation.lnk
>> Menu\Programs\PostGIS 1.3.5 for PostgreSQL 8.3\PostGIS 1.3.5 JDBC Driver
>> Documentation.lnk
>> Created uninstaller: C:\Program Files
>> (x86)\PostgreSQL\8.3\uninstall-postgis-pg83-1.3.5-1.exe
>> DataBase=postgis
>> Creating spatial database...
>> Completed
>> Looks like everything besides the error worked just fine. The log just
>> says "Skipped: libiconv-2.dll" in reference to the error. In fact, I just
>> thought to open up the installer (thanks to 7-Zip), and I compared the 2
>> libiconv-2.dll files - the one in the PostgreSQL bin folder and the one in
>> the PostGIS bin folder. The PostgreSQL file is larger (946kb vs 873kb) and
>> has a more recent last modified time (1/6/09 vs 12/16/08). I'm guessing
>> that I want the newer copy anyway, so perhaps skipping over that file isn't
>> such a bad thing. Why does PostGIS include that file in the first place if
>> it's included with PostgreSQL?
>> Geoff
> Hi Geoff,
> This is interesting; I remember I had a conversation about the libiconv DLL
> a while back, since the PostgreSQL installer used to install a really old
> version as libiconv2.dll, whereas MingW builds iconv as libiconv-2.dll (with
> the extra hyphen). The consensus at the time was that we should leave
> PostgreSQL to use libiconv2.dll and distribute our own libiconv-2.dll as
> part of the installer, but I guess this part has changed - I'll CC to Dave
> for comment, as I don't know which versions of the PostgreSQL installer
> contain this change.
> The reason that you see the error at the moment is, of course, because your
> current PostgreSQL instance already has the libiconv-2.dll file open for its
> own use.
> ATB,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090223/7c1629d8/attachment.html>
