[postgis-users] Operator precision
Kemal Bayram kemal at cins.co.uk
Wed Feb 25 02:43:02 PST 2009
Thanks, that solved the problem but I'm guessing that very large numbers do
not get indexed properly but then again if we're working with long/latitute
ranges normally I guess it's not really a concern.
> Add an "AND" clause that tests containment of the point
> against a rectangular polygon. Or that does explict
> ST_X(point) ST_Y(point) against your box. There's no way to
> change the box2d behavior, and it's a feature, not a bug
> (small boxes work better for large data sets, and spatial
> index results are expected to be over-determined).
> P.
> On Mon, Feb 23, 2009 at 3:58 PM, Kemal Bayram
> <kemal at cins.co.uk> wrote:
> > Hello all,
> > I'm a using PostGIS working with mainly points testing against 2d
> > bounded boxes, I recently came across a problem that is
> driving me nuts whereby:
> > select makebox2d(makepoint(32.25, 34.9375),
> makepoint(32.31249, 35))
> > && makepoint(32.3125, 34.996448);
> > returns false (as expected), where as:
> makepoint(32.312499, 35))
> > returns true.
> > 32.312499 cast as float4 is 32.3125, so I'm assuming that
> internally
> > single precision is being used. Is there any way change
> this behaviour?
> > Regards
> > Kemal
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
