[postgis-users] Operator precision
Paul Ramsey
pramsey at opengeo.org
Wed Feb 25 07:04:22 PST 2009
No, very large numbers do get indexed, they just don't get indexed
quite so precisely.
P.
On Wed, Feb 25, 2009 at 2:43 AM, Kemal Bayram <kemal at cins.co.uk> wrote:
> Thanks, that solved the problem but I'm guessing that very large numbers do
> not get indexed properly but then again if we're working with long/latitute
> ranges normally I guess it's not really a concern.
>> Add an "AND" clause that tests containment of the point
>> against a rectangular polygon. Or that does explict
>> ST_X(point) ST_Y(point) against your box. There's no way to
>> change the box2d behavior, and it's a feature, not a bug
>> (small boxes work better for large data sets, and spatial
>> index results are expected to be over-determined).
>> P.
>> On Mon, Feb 23, 2009 at 3:58 PM, Kemal Bayram
>> > Hello all,
>> > I'm a using PostGIS working with mainly points testing against 2d
>> > bounded boxes, I recently came across a problem that is
>> driving me nuts whereby:
>> > select makebox2d(makepoint(32.25, 34.9375),
>> makepoint(32.31249, 35))
>> > && makepoint(32.3125, 34.996448);
>> > returns false (as expected), where as:
>> makepoint(32.312499, 35))
>> > returns true.
>> > 32.312499 cast as float4 is 32.3125, so I'm assuming that
>> internally
>> > single precision is being used. Is there any way change
>> this behaviour?
>> > Regards
>> > Kemal
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
