[postgis-users] Error using PostGIS and GEOM
Paolo Rizzi
gis at oicom.com
Wed Feb 25 23:40:54 PST 2009
> * class org.geotools.data.DataSourceException: Could not count
> Request All Features
> * class org.postgresql.util.PSQLException: ERROR: function
> extent(geometry) does not exist
Does function extent() still exists in newer version of PostGIS or was
it removed and replaced by ST_extent()???
In the latter case, it's a Geotools problem, because it appears to be
using the old syntax.
Bye
Paolo Rizzi
> Hi,
> Thanks for your responses, I have tried all your suggestions, and also
> ended up re-installing the PostGIS. Using the Geoserver, I am trying to
> add a new Feature type with the polygon It now complains about the
> following error
> org.geotools.data.DataSourceException: Could not count Request All Features
> at
> org.geotools.data.postgis.PostgisFeatureStore.bounds(PostgisFeatureStore.java:764)
> at
> org.geotools.data.postgis.PostgisFeatureStore.getBounds(PostgisFeatureStore.java:676)
> at
> org.geotools.data.postgis.PostgisFeatureStore.getBounds(PostgisFeatureStore.java:653)
> at
> org.geoserver.feature.FeatureSourceUtils.getBoundingBoxEnvelope(FeatureSourceUtils.java
> Caused by:
> org.postgresql.util.PSQLException: ERROR: function extent(geometry) does
> not exist
> at
> org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.j
> Not sure what is causing this error.
> thanks!
> Giri
> On Wed, Feb 25, 2009 at 5:14 AM, Mark Cave-Ayland
> <mark.cave-ayland at siriusit.co.uk
> <mailto:mark.cave-ayland at siriusit.co.uk>> wrote:
> ???(Sinboy Zhang) wrote:
> I got the same problem.
> OS:CentOS 5.2
> PostgreSQL:8.2.6
> Geos:3.0.0
> proj:4.6.0
> postgis:1.3.2
> A few months ago,i installed them successully on Fedora 7,now a
> error boked when i installed on CentOS:
> ERROR: could not load library
> "/usr/local/postgis/lib/liblwgeom.so": libgeos_c.so.1:
> cannot open shared object file: No such file or directory
> But the file liblwgeom.so was existed surely in
> /usr/local/postgis/lib, i added /usr/local/postgis/lib to
> /etc/ld.conf.d/local.conf and execute ldconfig ,final restart
> postgresql ,but the error still exist.
> The error is telling you that PostgreSQL can't see libgeos_c.so.1 -
> you need to add the location of this file (normally /usr/local/lib)
> to /etc/ld.conf.d/local.conf and then run ldconfig so the OS can see
> it. On some older machines you may also have to restart the
> PostgreSQL server too.
> HTH,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> postgis-users mailing list
> <mailto:postgis-users at postgis.refractions.net>
