[postgis-users] How to excute dynamically a generated SQL command?
John Zhang
johnzhang06 at gmail.com
Sat Jan 3 17:57:32 PST 2009
Hi the list,
Referring to the PostgreSQL 8.3 documentation " 38.5.4. Executing Dynamic
Commands ", the command for executing a dynamic command is:
EXECUTE command-string [ INTO [STRICT] target ];
I am to execute an sql statement created dynamically, which is represented
in a variable sSql.
Here is an example:
sSql='INSERT INTO hm_raster.hm_airphotos( file_ext, airphoto) VALUES
('.tif', lo_import( E''C:\\HM\\Data\\Flightmap.tif'');';
EXECUTE sSQL;
It raises the error as:
ERROR: syntax error at end of input
LINE 1: ...E'C:\\HM\\Data\\Flightmap.tif')
I would appreciate a lot if you offer your input. Thanks a lot.
John
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090103/609b94de/attachment.html>
